lifter pre-load question
  • Thread starter Thread starter meangreen93
  • Start date Start date Dec 6, 2005
M
meangreen93
hialeah, swampland
Dec 6, 2005
  • Dec 6, 2005
hello everyone I almost finished with my 302 buildup (1993 mustang coupe 302 HO automatic AOD) its a stock bottom end with an F303 cam, stock heads with port work, stock valves with 5 angle grind, stock lifters and pushrods, and 610 maximum lift springs matched to the cam. I bought a brand new set of Scorpion 1.6 roller rockers and have them installed and this is where I am stuck.
should I install them with shims? do I need a longer pushrod? how do I determine what pre-load I need?
65ShelbyClone
4,675
38
119
Antelope Valley, SoCal
Dec 6, 2005
  • Dec 6, 2005
You just tighten the rocker bolt gently unto you get drag on the pushrod, then tighten it with a wrench you should have to tighten it ~1/4 to 3/4 turn before the rocker pedestal bottoms. If its less than that, you need a longer pushrod. If its more, you need shims. I wouldnt expect you to need new pushrods with your parts, though.
V
v8only
2,378
22
49
Dec 7, 2005
  • Dec 7, 2005
don't forget to be on the base lobe of the cam when you do this.
H
Ongoing Battle With Hydraulic Lifters
  • hailer06
  • Jun 8, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 9, 2026
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
What's your tow rig?
  • LILCBRA
  • May 31, 2026
  • Other Auto Tech
Other Auto Tech Oct 23, 2026
JH96GT
D
Heads Cam Intake
  • dropteeth
  • Sep 19, 2023
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 19, 2023
dropteeth
D
SURGING IDLE / NO IDLE CHECKLIST FOR 1999–2004 MUSTANG GT (4.6L 2V) - Work In Progress
  • Noobz347
  • Aug 30, 2025
1996 - 2004 SN95 Mustang -General/Talk- Aug 30, 2025
