lifter trouble
my stang was running horribly and i just got the engine back together its a 347 i took the intake off and suspected my lifters so i took em to to find that more than half were dented/ broken. (it sould be noted that a major disaster with water getting into my engine happened 3 weeks ago but I fixed that problem) here are my questions
1. can the water have resulted in my hydraulic flat tappet liffters getting messed up
2. is my camshaft ok/ could the lifters have destroyed the cam lobes
3 would the damaged lifters have caused my car to shake, not run smoothly, and perform very poorly????
If the lifters are trashed, so is the cam. The bearings will be as well. You'll have to start all over again. I doubt the water had anything to do with it. It didn't help, but I've seen many engines run fine with a milkshake in the oilpan. And depending on how much water got into the cylinders, you could also have bent connecting rods. Water does not compress. If there's enough to over fill the compressed volume at TDC, the rods are what will give first. You'll need to completely tear it all down and check everything to see if anything can be reused.
You had two seperate problems:
1. The wrong head gaskets. You fixed this problem. And its not related to-
2. Your cam is flat and ate the lifters. You get to rebuild the engine again!
If you google "flat cam" or "bad lifters" you'll find you aren't alone. They took all the ZZDP out of the oils we have today because modern cars with roller cams don't need them.
I don't know what the rate of failure is, but it seems like everyone I know who builds an engine with a non roller cam does it twice till they get the combo of oil/additives right.....
It's not just the additive change that wipes cam lobes. I had two failures and neither were due to the lack of zinc phosphate. Both were due to either bad lifters or too much lube at startup. Both had a single lifter & lobe failure and both in the first 20 minutes run time. In both cases the cam lobe failed to rotate the lifter in it's bore.
I've too been reading about this happening quite often. Not to bash on any one manufacturer, but it seems as though Comp Cams' name has come up more times than not. I've also read that it's the break-in that kills them. GM has an additive that can be purchased from the dealer that can be added for break in.
