light not working in PRNDL
The center console is not hard to remove. Start by removing the trim ring around the gear shift lever. It is held in place by friction clips.
However, IMO anybody doing much of any work on their Mustang is better served by having a Chiltion's service manual (or any other brand) of their own. It contains detail (with instructions and pictures) that is well worth the $20 cost of the manual.
This will also give you the wiring diagrams that may come in handy should you find out the bulb is actually OK.
First do as he said and take out the trim around the gear shifter where the cig lighter is located, then open the center box and remove the two little rumber inserts that hide the screws that hold the box in... the remove the little black box and then u will see two 7 or 8 millimeters screws that hold the console down.. remove them and wires u can anchoring the console down and u can remove the console. Then i would turn the headlights and and check for power on the brown wire and ground on the black wire, be aware this light only comes on when headlights and turned on... then if u have power and ground when lights are on your bulb is bad and u will need a t-20 i think to take out the two screw that hold the prd21 plastic peice down and the other side just pops up with a little pressure from a screw driver and wa la you can remove the light to replace bulb...
