  • Mustang Sound & Shine All
lightbar install and holes
  • Thread starter Thread starter mysticspirit25
  • Start date Start date Jan 30, 2004
M
mysticspirit25
22
  • Jan 30, 2004
The holes that are drilled into the panels to access the bolts on the lite bar...CDC gives you cheap caps that do not stay put. Is there anyplace that I can get caps to cover the holes that actually have some sort of flange on them so they will stick in the hole, the caps that CDC gives do not have any sort of flange.
R
Red2000GT
2,450
Regina,Sask.Canada
Jan 30, 2004
  • Jan 30, 2004
Sounds like a run to the local parts store and a look through the HELP! section is in order. If that doesn't work,then maybe a little blue or something to hold the caps in place. Not too much to make it permanent but enough to keep them there.
T
Tstang90
2,380
Long Island,NY
Jan 31, 2004
  • Jan 31, 2004
Hmm I installed a CDC bar on my vert theres no access plugs on mine. But maybe come black silicone will help hold em in so it blends. With your bar. Just prep the surface to remove any armor all etc.
A
aceman65
43
Bemidji, Mn.
Jan 31, 2004
  • Jan 31, 2004
Do you like the loks of the bar? Thinking about getting one.
I used to work at a hardware store and they had round rubber plugs different diameters- flat with a flange lip that would work. You can probably find a plastic one as well pretty easy. Whats the diameter of the hole?
M
mysticspirit25
22
  • Feb 1, 2004
ummm, I love the looks of the bar, I will post a pic of my stang....the hole is a 1" diameter....I am off to home depot to look for rubber plugs.
D
2006 GT Windshield Cowl install
  • Daddidio
  • Mar 12, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Mar 12, 2026
Daddidio
D
'67-68 Scott Drake Trap Door w/6x9 Speaker Pods
  • bchampion
  • Jun 15, 2025
1965 - 1973 Classic Mustangs -General/Talk- Jun 16, 2025
bchampion
L
2012 Seats in 98 GT Convertible - pictures coming
  • lparsons42
  • Aug 11, 2025
1996 - 2004 SN95 Mustang -General/Talk- Aug 17, 2025
lparsons42
L
  • Locked
Drivetrain Adjustable clutch cable questions
  • Scott_S
  • Oct 31, 2025
Fox 5.0 Mustang Tech Oct 31, 2025
H
Ongoing Battle With Hydraulic Lifters
  • hailer06
  • Jun 8, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 9, 2026
