lightning heads
  • Thread starter Thread starter Lang
  • Start date Start date Jul 3, 2006
L
Lang
17
Lorain, Oh
Jul 3, 2006
  • Jul 3, 2006
Hey, Is there any advantage to using the heads off the 351 lightning trucks or are they the same as the gt-40's or gtp's?
Thanks
Mustang5L5
Mod Dude
Feb 18, 2001
43,347
18,082
224
Massachusetts
Jul 3, 2006
  • Jul 3, 2006
I beleive they are GT-40 heads
TheBocSez
652
Converse, TX
Jul 3, 2006
  • Jul 3, 2006
Thanks
They are GT40 Heads, the down side of using them from a Lightning instead of a Cobra are
1. They have 1/2 inch bolt holes so you will need step washers or bolts. (not a big deal)
2. They have a larger combustion chamber 69cc I believe which will lower your compression ratio depending on your pistons to under 9.0:1.
You could mill them, but it would have to be a lot to bump the compression back up and for the amount you would spend, I would go with some GT40P's and new headers needed to make em work.
85_SS_302_Coupe
6,945
1,598
223
Northern KY
Jul 3, 2006
  • Jul 3, 2006
+1. I'm in the same boat though with some '69 351W heads....they're ported and polished really nicely though, probably will out perform P heads, but they need a new set of valves....
R
R2D2
Jul 4, 2006
  • Jul 4, 2006
how about some aussie 2v closed chambers?
LOL j/k man
f4fntm
88
Olympia, WA
Jul 4, 2006
  • Jul 4, 2006
The low compression would be fine with forced induction, no?
85_SS_302_Coupe
6,945
1,598
223
Northern KY
Jul 4, 2006
  • Jul 4, 2006
LOL j/k man
Nah screw that, i'm all about some Boss canted valve heads
TheBocSez
652
Converse, TX
Jul 4, 2006
  • Jul 4, 2006
Sure. The lower compression would allow more boost with less chance of detonation and the lightning was supercharged.
rd
3,316
63
109
Ocean Springs MS
Jul 4, 2006
  • Jul 4, 2006
I believe they have the 62-64 cc chambers like other GT40s.
I have a set on my 82, milled a bit, and they were a big step up from stockers.
Engine Felpro 9333 pt1 (with 8psi boost)
  • JD1964
  • Jan 14, 2026
Fox 5.0 Mustang Tech Feb 1, 2026
Qtrhrse23
G
Electrical Getting good ground in 1991 Fox Vert for amps - getting popping noise when I turn on the lights?
  • gvanginkel403
  • Apr 11, 2026
Fox 5.0 Mustang Tech Jul 21, 2026
gvanginkel403
G
Speedometer Calibration
  • Sonny Bibb
  • Sep 11, 2026
  • Digital Self-tuning Forum
Digital Self-tuning Forum Sep 13, 2026
Sonny Bibb
G
Resolved Smoking Wiring Issue After GT40 Head Swap
  • Grapes
  • Aug 15, 2026
Fox 5.0 Mustang Tech Aug 22, 2026
Grapes
G
A
Old Holley head identification???
  • Ar15cobra
  • Jan 27, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 27, 2026
AeroCoupe
