  • SN95 4.6L Mustang Tech
lights cut off?
  • Thread starter Thread starter BadMoFo
  • Start date Start date Jan 4, 2004
BadMoFo
I will sleep with a Mod for a CT
2,911
New Bern NC
Jan 4, 2004
  • Jan 4, 2004
about 3 weeks ago I posted that my head lights were dimming and getting brighter as I drove. Well tonight as I was driving they completely turned off and on a few times, came back on for about a mile then flashed on and off again and then went off for about 40 seconds before coming back on again. luckily my fog lights didnt go off. I was told previously it is probably my alternator does anyone have a different opinion?
poolee
97
melbourne, fl
Jan 4, 2004
  • Jan 4, 2004
I had the same thing happen a while back. But, when it cut out, my ABS light kicked on and then everything died but the motor. I was only a block from the house and I had to keep it in 1st gear to keep it alive. Changed the alternator and battery and everything has been good since.
GoBabyVroommm
1,156
Chicago, For Realss???!!!
Jan 4, 2004
  • Jan 4, 2004
Well i had that problem too but it was only when i turned on the fog lights. Sometimes all the lights inside the car will flash on and off. Next time it does it turn off the fogs and see if your head lights stay on. Its a short good luck in finding it.
K
KGcobra
131
Florida
Jan 4, 2004
  • Jan 4, 2004
Did your dash lights cut out or dim as well? If your fog lights (and dash?) stayed on then I would assume the alternator might be alright, and the main headlamp switch is still ok as well.
You might want to check out your bulbs and their connections though. A while back I had a problem where it seemed like one of the headlights was going out on me. Whenever I would get to check the light it was lit up just fine though. It turns out the one was just getting really dim periodically and from inside the car it seemed almost completely out (the other side and the fogs stayed on though). It took a while for me to catch the condtion. After replacing that bulb the problem went away. I had taken it to the dealer so didn't inspect the old bulb but I'm guessing the filament~plug connection within the bulb was messed up and vibration/bumps would cause it to go in and out of whack.
BadMoFo
2,911
New Bern NC
Jan 4, 2004
  • Jan 4, 2004
fog lights and interior lights stayed on. it was both headlights not just one. no other lights came on or went off, no abs light, or check engine or nothing. all guages read normal.
poolee
97
melbourne, fl
Jan 4, 2004
  • Jan 4, 2004
Sounds like it may be a bad ground somewhere or possibly a weak fuse. A bad alternator should show up on a gauge.
Sam98
1,625
Albuquerque, NM
Jan 4, 2004
  • Jan 4, 2004
Sounds like the multi-function switch in the steering column to me.
BadMoFo
2,911
New Bern NC
Jan 4, 2004
  • Jan 4, 2004
C
claytucc3
825
Santa Clarita, Ca
Jan 4, 2004
  • Jan 4, 2004
sounds like it may be a ground to me as well, There are two grounding bolts in front of both headlights that are painted green make sure that they are tightened and have good contact. I believe those ground the lights and also the gem. When I was installing my MSD i accidentally left one of those loose and it caused my lights to dim. Also do you have any amps or anything like that and you can get your alternator checked for free at most bigger car parts stores
BadMoFo
2,911
New Bern NC
Jan 4, 2004
#10
  • Jan 4, 2004
  • #10
no amps or anything other than the mach 460. will tighten the bolts in the morning and hopefully that helps, got a frined who works at advanced auto so maybe I can have him check it this week.
GoBabyVroommm
1,156
Jan 4, 2004
#11
  • Jan 4, 2004
  • #11
Time to sell the car and get a LS1 or civic. j/k
Sam98
1,625
Albuquerque, NM
Jan 5, 2004
#12
  • Jan 5, 2004
  • #12
BadMoFo said:
It controls the turn signals, high beams, etc. Sometimes the contacts get corroded and make the headlights intermittent.
1997 gt Starts then dies a few seconds after.
  • 97orange
  • Aug 13, 2026
SN95 4.6L Mustang Tech Aug 17, 2026
97orange
9
I
Engine Help requested in identifying how to resolve engine light issue
  • Ianslaney
  • Oct 4, 2026
SN95 4.6L Mustang Tech Oct 4, 2026
Bullitt347
E
2007 GT Stalls when lights or a/c turned on
  • ejscarfo
  • Jun 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Sep 26, 2026
manicmechanic007
D
Running both lean and rich with O2 heat codes
  • Danceswithfire5
  • Aug 30, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Sep 5, 2026
apple99Mustangdude
A
T
Progress Thread 2002 Mustang 3.8L CV
  • TheIncompetentMechanic
  • May 26, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jun 1, 2026
T
