Like the oil thread,... what plugs u running?
93project
549
52
38
El Paso, tx
Very curious as to what fellow foxers are using for plugs? I've always used autolite copper plugs and now that the new engine has aluminum heads, I'm not so sure...
Right now it's got the autolites, but I'm told to use NGK V Power. I once tried the V powers in my old 302 that sported GT40 iron heads, and a complete aftermarket ignition. I lost most of the plugs on the freeway. Car began misfiring like mad, I pulled over to find 7 of 8 NGK's had shattered porcelain :shrug:
Quit using that brand since...
What do you guys have good luck with ?
NGK in the race car
NGK in my 88lx
NGK in my volvo
NGK in my old eclipse
NGK in my prelude
NGK in my girls altima
NGK in my civic
NGK in my lightning
NGK in 95 GT
NGK in every 03cobra ive ever worked on...
NGK in everything... ZERO issues
I run whatever copper plugs were recommended by Trick Flow in my Twisted Wedges. Autolites I think, but I don't remember the number.
Prior to that, I ran Autolite Iridium plugs in the stock heads. Those plugs are more expensive, but I like the fact that you never have to re-gap them, and they will basically outlast your engine. I actually still have those plugs sitting on my shelf. They don't fit in the TW heads, otherwise I might have used them. They're still in perfectly good shape.
I like to stick with copper plugs. NGK doesnt actually make a copper plug. I've always had the best luck with Autolite's in the stang. I am not dissing NGK, I will agree that NGK is probably the best all around plug for any type of engine, i've used them before in the stang and didnt notice a difference from the Autolites. I tried motorcraft one time and it just didnt seem to run the same but I cant exactly say it was because of the plugs, but that was a while ago. I run factory motorcraft plugs in my ranger though.
I think if you had 7 out of 8 porcelains cracked or shattered on the plugs, that it just might have been an install problem, you would have noticed cracked and shattered porcelain when you gapped and held the spark plugs. It's easy to crack a plug if you don't have the socket on perfectly straight when tightening the plugs down. I run ngk v gapped at .040 - .044 never had a problem yet.
