Lincoln Mark VIII
What is needed to put a Lincoln Mark VIII 4.6 32v in my car? I'm sure the tranny will bolt up and everything, being a 4.6. I would assume, cobra intake manifold because if i remember right the lincoln pulls air from the drivers side of the engine bay, not the passenger.
Any links? Thanks
How many bolts on your current flywheel? Is it the Windsor 8 bolt PI motor and from your sig, I believe it is or is it a Romeo 6 bolt? The Mark VIII 4.6 requires a 6 bolt flywheel.
The Mark VIII's air filter is on the passenger side.
As mentioned, you will need 4V headers as the Mark's won't clear your steering column.
You will need to use yours or acquire a Mustang Oil pan as the Mark VIII one won't work.
Wiring it in will be lots of fun. That is all I can remember right now...
