  • 1994 - 1995 Specific Tech
Line Lock HELP.........
  • Thread starter Thread starter AIRRIDE
  • Start date Start date Nov 14, 2004
A
AIRRIDE
33
Ontario,Canada
Nov 14, 2004
  • Nov 14, 2004
Has anyone have any info on installling a line lock in a 94GT,If some can me out that would be great with step by step intrustions,pics would be great too.thanks.
W
wytstang
Mustang Master
Mar 14, 2004
4,988
Summerville,SC missing South Fl. weather :(
Nov 14, 2004
  • Nov 14, 2004
Here
Stangfreak95
add a 4
3,571
In your sister. If none, your mom
Nov 14, 2004
  • Nov 14, 2004
Here's pic of the final install on mine. You dont have to bother plugging it in the ABS install BTW.
A
AIRRIDE
33
Ontario,Canada
Nov 14, 2004
  • Nov 14, 2004
THANKS FOR THE PIC
A
AIRRIDE
33
Ontario,Canada
Nov 14, 2004
  • Nov 14, 2004
Is the 94-95 master brake cylinder the same.
A
AIRRIDE
33
Ontario,Canada
Nov 14, 2004
  • Nov 14, 2004
do you have any more pics,Is the brake line on the left coming of the line lock going to the distrbtion block on the top right hole.
Stangfreak95
add a 4
3,571
Nov 14, 2004
  • Nov 14, 2004
Sorry I dont have any more pics...Looks pretty clear to me man
The brakeline on the left coming out of the linelock goes to the top LEFT hole of the distributor block, the one that is CLOSER to the firewall.
Good luck
A
AIRRIDE
33
Ontario,Canada
Nov 14, 2004
  • Nov 14, 2004
Good luck
From the pic it looks like the brakeline on the linelock the left one (toward firewall) goes to the master cylinder and the right one tward the front of the car is going to the distrubtion block.
Stangfreak95
add a 4
3,571
Nov 14, 2004
  • Nov 14, 2004
ok now you confused me with the terms.
The thing on the left is the master cylinder(which I tought you called the distribution block) and the thing under the linelock is the proportional valve (your distributor block).
so the left side of the linelock goes to the top left hole(closer to the firewall) of the master cylinder. And the right side of the linelock goes to the top left of the proportional valve.
Sorry for the confusion.
A
AIRRIDE
33
Ontario,Canada
Nov 14, 2004
#10
  • Nov 14, 2004
  • #10
ok thanks for the info
mytight95
2,605
Dothan,Al
Apr 16, 2006
#11
  • Apr 16, 2006
  • #11
i did mine same as stangfreaks..... works perfect
jason
nmcgrawj
Advanced Member
Sep 28, 2003
3,651
Indianapolis, IN
Apr 16, 2006
#12
  • Apr 16, 2006
  • #12
So where does the ABS come into play? Up front? So does it not think the brakes are locked up?
Stangfreak95
add a 4
3,571
Apr 16, 2006
#13
  • Apr 16, 2006
  • #13
I dont know man. All I know is there is absolutely no connections to the ABS system. I never had any ABS light or braking problems when I had the linelock plugged in the brake lines. Really it is a simple install. You just need the flaring tools and 2 small brake lines to do it.
mytight95
2,605
Dothan,Al
Apr 16, 2006
#14
  • Apr 16, 2006
  • #14
i didn't even use the flaring tools, i bought the correct size,flared, and length line already made at my parts store, used the correct adapters bent the line, and used teflon sealant to seal it up to be safe..... and VOILA done
jason
ddr1stang
57
#15
  • Apr 16, 2006
  • #15
I installed mine on the abs block just because theres a hell of alot more room to work
nmcgrawj
Advanced Member
Sep 28, 2003
3,651
Indianapolis, IN
Apr 16, 2006
#16
  • Apr 16, 2006
  • #16
pics and/or details? Care to do a quick paint shop drawing?
ddr1stang
57
#17
  • Apr 17, 2006
  • #17
Here
http://www.corral.net/forums/showthread.php?t=613782&highlight=line+lock
This is how I mounted mine (on abs block) just buy a summit roll control valve and then go to napa and buy the fitttings and 2 pc of brake line. You will need a flaring tool for when you cut the stock brake line to use a standard sae fitting.
sage2k
645
Baton Rouge, LA
Jul 26, 2006
#18
  • Jul 26, 2006
  • #18
what does a flaring tool look like? and what size fittings do i need?
sage2k
645
Baton Rouge, LA
Aug 13, 2006
#19
  • Aug 13, 2006
  • #19
what size fittings were used
sage2k
645
Baton Rouge, LA
Aug 14, 2006
#20
  • Aug 14, 2006
  • #20
>___<
Paint and Body Door Latch Issue
  • KRUISR
  • Oct 9, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
General karthief
J
Suspension Foxbody mustang Steering shaft issue
  • Jakub2537
  • Sep 5, 2026
Fox 5.0 Mustang Tech Sep 11, 2026
gkomo
D
Please help with vacuum lines
  • Dawgs000082
  • May 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 10, 2026
Dawgs000082
D
Hammer shifter problems
  • 387lx
  • Apr 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 11, 2026
General karthief
Crank no start on a turbo and cammed pushrod 5.0
  • 1630stri
  • Sep 2, 2026
  • Digital Self-tuning Forum
Digital Self-tuning Forum Sep 16, 2026
Qtrhrse23
