Line Lock
  • Thread starter Thread starter Cobain03
  • Start date Start date Jul 22, 2006
Cobain03
996
Lexington, Ky
Jul 22, 2006
  • Jul 22, 2006
How hard is it to install one of these? someone give a step by step?
Shakin66
628
Waycross, Ga / Lake James, NC
Jul 22, 2006
  • Jul 22, 2006
I just installed mine 3 months ago and there is nothing to it. I bought a new Granatelli unit off of ebay cheap and have been really happy with it. Keep in mind you will be letting air back into the brake lines so bleeding is nessesary afterward which proved to be difficult as you are going to be trapping air in the soloniod. If you have a Mity vac pump it makes bleeding them down easier. The rest is just straight forward electrical connections and you'll have a light to mount that illuminates when the system is turned on and switch which I hid under the shifter boot so its able to be held in my right hand. The instructions that come with them are good and you should allow yourself a full day and a couple of trips to the parts house for differing brake lines and adapters.
dennis112
1,561
36
79
Amish Wonderland of Central PA.
Jul 22, 2006
  • Jul 22, 2006
I bought the Summit brand line loc that looks like a Hurst Roll Control. I also bought the Summit universal installation kit. It included some tubing and several adapter fittings. Seemed a little pricey when I bought the installation kit ($25) but it had everything I needed for the conversion and so I spent zero time out running for parts.
You should also have a double flair kit on hand and some tubing bending tools to make life easier. I probably had an afternoon in mounting the line loc and wiring it up.
I think the hardest part was finding ample space on the apron since I also have an adjustable proportioning valve mounted there too.
The instructions were sufficient. You can view them on the Summit web site--check out both the instructions for the Summit brand and the Hurst brand (which is more detailed.) Just pull up the appropriate part # of the line loc and check out the description--there is a link to the PDF file.
Cobain03
996
Lexington, Ky
Jul 22, 2006
  • Jul 22, 2006
wait a minute, you gotta bleed the brakes after every use?!?
iskwezm
4,159
20
79
Rowland Heights,California
Jul 22, 2006
  • Jul 22, 2006
no,just when you open the line to install it.
M
mustangdave
My rearend needs a stud and two nuts.
2,976
North Carolina
Jul 22, 2006
  • Jul 22, 2006
If you can find the appropiate adaptors, you will not need to flare any lines.
Shakin66
628
Jul 23, 2006
  • Jul 23, 2006
Thats true about the installation kit, its a must have for this job. I recall now that my trips to the parts house were for fittings, lines and adapters for the Baer master cylinder and proportional valve.
G
2019 GT Line lock
  • gray owl
  • Jul 18, 2026
  • 2015 - 2023 (S550) Mustang -General/Talk
2015 - 2023 (S550) Mustang -General/Talk Jul 25, 2026
gray owl
G
Fox Brake lines hitting bump stops
  • keel
  • Sep 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 24, 2026
keel
P
Rear disk brake caliper parking brake adjustment
  • parrotguy
  • Oct 23, 2025
1974 - 1978 Mustang II Talk & Tech Oct 24, 2025
2Blue2
Paint and Body Door Latch Issue
  • KRUISR
  • Oct 9, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
General karthief
J
89 mustang alarm install to lock and unlock
  • jk66
  • Apr 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 10, 2026
jk66
J
