LineLock installed ,pics here
Slow5.0
2,554
Portland, OR
I installed Summit LineLock http://store.summitracing.com/partd...0000&N=4294922533+4294920388+115&autoview=sku
Installation wasn't that bad except i had to made3 trips to AutoZone because off wrong fittings, but i gotit done
step on brake pedal.
push button.
release brake.
front brakes stay on (locked) rear brakes are off
give gas.
make smoke
push button to release front brakes
Ernie, you should make a install guide outlining what you needed and how you installed that kit. i'm interested in picking one up
push button.
release brake.
give gas.
make smoke
I though the point of a line lock was to keep the car from moving when you are on the line? That seems ind of odd that you would have to actually push the button while you are starting a run.
Like i said i had to make 3 trips in AutoZone because non of those breake lines didn't fit
I came up with 2 3/16 12" double flare breake lines
1 3/16 inverted flare breake line (shortest one you can get because you gonna use two fittings from that inverted flare breake line)
One hex plug (1/8 NPT) if you gonna use LineLock that have 1 IN and 2 or 3 OUT ,if is only 1 OUT than don't need this plug
21/8 to 3/8-24 adapters
Flare tool (can be rented in AutoZone)
Because Line lock uses inverted flareand Ford uses double flare i had to cut off 2 double flare lines and use 2 inverted fittings from that shortest inverted line and then use flare tool and make it inverted so that end will fit on Line Lock side
Sounds crazy but thats only was i can do (i tryed find parts in AUtoZone and AdvanceAutoParts but non of them have breake line that is double on one and inverted on another side or adapter from double to inverted flare
I bought "Kill switch" just for safery reason ,and one LED light
Wiring go like this
Ignition wire - Kill switch - LineLock push button - LED light - LineLock (and i grounded LineLock to battery)
I spend about $17 on those parts plus cost of LineLock (i had some breake fluid from before so you may need little bit to belld brakes ,its good to blead all 4 calipers like i did
So for 90 some bucks you can have this in your car
I hope you guys understand my writing (probably not)
Let me know if you have some more questions
I think you're thinking of a trans break for automatics, which engages 1st and reverse gears simultaneously so the car doesn't move after staging while you are applying part throttle before starting the run.
