linkage help asap!
  • Thread starter Thread starter mustangmike6996
  • Start date Start date Oct 11, 2011
mustangmike6996
5 Year Member
Nov 10, 2005
483
clinton twp, MI
Oct 11, 2011
  • Oct 11, 2011
i just got back into town and decided to start working on my mustang again... im in the process of installing the clutch linkage... theres a problem tho... the car was and auto and has had the majority of the floor and frame replaced... the bracket that holds the Z-bar to the frame rail has no holes to mount it... i obviously need to drill holes to bolt it down, but where can i gain access to the nuts for the back side... there are not any really good pics on the net. any info would be great. thanks
mustangmike6996
5 Year Member
Nov 10, 2005
483
clinton twp, MI
Oct 11, 2011
  • Oct 11, 2011
anyone?
dennis112
1,561
36
79
Amish Wonderland of Central PA.
Oct 12, 2011
  • Oct 12, 2011
More than likely the new frame does not have "hidden nuts" that you drill to find.
You will need some type of a crush nut that you can add from the top of the frame. Might want to look at the crush nuts that are used on power steering cars? Not sure of their size but the idea is the same.
You might contact a Mustang rebuild shop (like what CJ Pony parts offers) and see what they recommend when they do restorations.
mustangmike6996
5 Year Member
Nov 10, 2005
483
clinton twp, MI
Oct 19, 2011
  • Oct 19, 2011
thanks.... as you suspected, it didnt have the hidden nuts. i drilled the two holes in the top frame rail and cut a 1" x 1/2" access hole on the outside frame rail away from the power steering bolts so i can use a wrench with what i would call a "washered nut" and set it inside the box end of the wrench for install and removal. man this pedal/brake booster/master cyl/ linkage swap has been hell.
65coupe408w
192
  • Oct 19, 2011
could be a good time to install a hydraulic clutch setup or cable clutch? just a thought
68dustin
173
  • Oct 19, 2011
what type of tranny are you putting in??? i went with cable... so much easier!
Engine Radiator with no shroud provision... What to do?
  • FastDriver
  • Apr 22, 2026
Fox 5.0 Mustang Tech Apr 25, 2026
FastDriver
T
Convertible A-pillar weatherstrip issues
  • thiefofcheese
  • Oct 24, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 20, 2025
AeroCoupe
V6 to V8 Swap info
  • 02_2v_Curtis
  • Jan 11, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 7, 2026
2v_johnny
M
  • mnky99
  • Sep 5, 2025
mnky99
M
'03 GT Fuel Pump/Pressure/Delivery Issue
  • Brodach
  • Oct 21, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 31, 2025
gkomo
