Little computer help
89LXNotchPI
21
Washington
My car has been backfiring through mnifold ever since I reset my comp about a week ago. However, it only backfires when in gear(AOD) not in park or nuetral. I'm thinking it has to be coomputer related, getting way too much fuel at idle, the idle is really rough, timing is fine, TPS is fine. Backfiring stops after the car revs over 2,000 rpm. Any help or ideas would be appreciated. Also, what is the ebst way to clean the 10-pin connectors? Thanks for any help.
Dump the codes and see what the computer says is wrong…
Here's the link to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great.
See http://www.troublecodes.net/Ford/
OR
See http://www.mustangworks.com/articles/electronics/eec-iv_codes.html
IF your car is an 86-88 stang, you'll have to use the test lamp or voltmeter method. There is no functional check engine light on the 86-88's except possibly the Cali Mass Air cars.
For those who are intimidated by all the wires & connections, see http://www.actron.com/product_detail.php?pid=16153 for what a typical hand scanner looks like. Normal retail price is about $30 or so at AutoZone or Walmart.
Or for a nicer scanner see http://www.midwayautosupply.com/detailedproductdescription.asp?3829 – It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $35.
i dont get it the site dosnt tell me how to pull codes on my musatng it says liek diesil and stuff and i dont know where the DLC is anyway i gotta stock rebuilt 302 and i wanna get soem codes out because it has been running odd so if anyone can explane or have a diff site to go to it would b a great help
Dump the codes and see what the computer says is wrong…Codes may be present in the computer even if the Check Engine light isn’t on.
OR
attachment.php
index.php
index.php
For those who are intimidated by all the wires & connections, see http://www.actron.com/product_detail.php?pid=16153 for what a typical hand scanner looks like. Normal retail price is about $30 or so at AutoZone or Wal-Mart.
Or for a nicer scanner see http://www.midwayautosupply.com/pc-7208-90-equus-digital-ford-code-reader-3145.aspx – It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $30.
