Little preview of the new set-up...
Redsnk95
2,243
Houston, TX
The pics are very big so I will just post the link to the pics. I still have a lot of wiring but this is more/less what it will look like. As you can see I also have some cleaning to do. You can also see the alternator bracket that I found that will actually work, just use a foxbody crank pulley.
http://www.mustangmods.com/data/102/engpreview1.jpg
http://www.mustangmods.com/data/102/engpreview2.jpg
Here is the cut-off switch in the back.
http://www.mustangmods.com/data/102/cutoff3.jpg
http://www.mustangmods.com/data/102/cutoff4.jpg
Looking for high 10s on motor and deep 10s on some nitrous. Weight will be around 3300-3350 with me in the car.
I will post more pics when it is closer to being done.
Troy
See if I can answer some questions here.
CMan: A basic run down would be:
347 11.5:1
AFR 205s
AFM N91 cam
TFS R lower
TFS Box upper
90mm throttle body
80mm PMAS meter
AFM 4" pipe
1 3/4" Mac headers
C4 w/ PI Converter ~4200rpms
4.30 gears
PMS tuned (of course)
PUMP GAS!!!
If there is something I missed let me know.
As for the thermostat..lol..the duck tape will be removed. I will not be using a thermostat just some washers along with the electric water pump.
RC: I try to get back here when I can.
Rio: The inlet is 4" from AFM. The fuel rails are from Behind Bars Race Cars...they are awesome NO WASHERS/SPACERS needed. I do have to do some work for the ECT sensor though.
Blackvert: Yes will be all motor for now...hoping for high 10s on motor on pump gas. I will add a NX plate kit to go deep into the 10s on 104 unleaded.
Troy
Ok lets see here....
94-302-vert:
Trailer only car, not street time pretty much impossible to get an emissions sticker now here in Houston and the tickets for no emissions is ridiculous.
Zenboy99:
The heads and intake are box stock. The ports mated up pretty damn well, I was impressed. 11.5:1 on pump gas is something we are going to try...just have to see how the motor likes it.
As for the alternator bracket it is a direct bolt on provided you have no other accersories. But this one did not line up like I wanted and Roush is being a PITA about it so I am going to make my own.
ProKiller: Yes they are TFS cast shorty valve covers ~$99.
Chris: Thanks man I'm trying hard to get back on it...my new job is at a performance shop so now we spend time on other cars instead of our own.
Troy
