Locking header bolts?
  • Thread starter Thread starter DW5.0L
  • Start date Start date Jul 8, 2005
DW5.0L
172
Florida
Jul 8, 2005
  • Jul 8, 2005
What is the right underhead length needed, 1.000 or .75? I am going to put on my BBK shorites and have learned after reading numerous threads that the bolts are junk. I am looking at the FMS or Stage 8 locking bolt sets. E7 heads on my block.
Maryland Stang
1,656
30
39
Greenville, NC
Jul 8, 2005
  • Jul 8, 2005
1"... I have Stage 8 on my headers and they haven't budged since I installed them.
DW5.0L
172
Florida
Jul 8, 2005
  • Jul 8, 2005
Thanks.
I
Insane3D
310
  • Jul 8, 2005
1" may work, but .75" is stock length. Be careful not to screw up the threads with a longer bolt...
IMO, locking bolts are a waste of $$$ anyhow...
If you simply snug them up a few times after a few heating/cooling cycles, they will stay put. I used ARP 12 point SS header bolts, and they are much nicer than the POS Stage 8 locking bolts they replaced. The FMS and the Stage 8's will rust FYI...
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Jul 8, 2005
  • Jul 8, 2005
In the day of my youth I was an aircraft mechanic, so I still do some things that way. I got some 1" long 3/8" course thread, stainless steel allen head bolts for my headers. The bolt heads were drilled with a #52 drill bit (about .040) using a drill press and lots of WD40 to cool the bit. The head is drilled with the holes in a cross pattern at 90 degree angles to each other.
I bought a 5/16" Bondhus Balldriver Allen wrench, it works like a universal joint. You can tighten up the Allen head bolts at 15-20 degrees off center angle and still get everything tight. Cut the "L" part off the wrench with a cutoff wheel and stuck the straight part in a Allen socket. This works great, cause the Allen heads are smaller than even the 12 point bolt heads, and with my fancy tool I can tighten them up with a torque wrench.
Torque the bolts down and pull off about 12" of .032 stainless steel safety wire. Thread the wire through 2 holes, or just one if the other one is blocked by the header pipe. Pull the wire through until the ends are even. Twist up about 2" with your handy-dandy safety wire twister pliers, making sure that the wire pulls the bolt tighter as it routes across the header pipe. Make sure the twist ends at the wire hole in the next bolt, and that it pulls the bolt in the tightening direction. Thread it through and twist up about 3/4"of wire on the other side of the hole and cut it off evenly. Fold it over about midway so that the sharp end doesn't stick you.
Another trick...
I have a cheap fix - get some 18-20 gauge sheet steel and cut 16 pieces of metal into strips 9/16" wide x 3/4" long. Drill a 3/8" hole centered side to side and 1/2" from the end of the metal strip. Use this strip as a washer, with the tab positioned pointed up towards the rocker covers. When you finish tightening the bolts down, take a screwdriver and a hammer, pry the tab up and then beat it down tight against the flat sides of the bolt head. If you use hex head bolts they will never back out again. You may have to play with the dimensions a little to clear you particular set of headers, but it will work good.
Maryland Stang
1,656
30
39
Greenville, NC
Jul 8, 2005
  • Jul 8, 2005
Most aftermarket headers use a thicker flange hence the 1" bolt. I have them on my Flowtechs.
Stage 8s have been recently redesigned. Much nicer now. And I have no rust on my old design Stage 8s.
Michael Yount
Mustang Master
Apr 10, 2002
9,039
Charlotte, NC
Jul 8, 2005
  • Jul 8, 2005
If you measure to be sure the flange is true/flat - it is extremely unlikely you'll have a problem with loosening header bolts. The problem is that many headers - even brand new ones - have warped flanges. Trying to pull that into a flat position with the bolts is what stresses them unevenly and leads to loosening bolts and leaks.
Check the flange - have it milled if necessary - then just snug your bolts down, heat cycle, re-snug -- and they should stay right where they are. Ever wonder why the factory never uses locking bolts on their headers/manifolds? Because they don't have to - the flanges they use are flat/true.
DW5.0L
172
Florida
Jul 8, 2005
  • Jul 8, 2005
Good point. With 197,000 miles my OEM headers never leaked. Looks like those bolt kits aren't needed. I will make sure the flanges are true. What about a Mr Gasket cooper gasket? Is that unecessary as well?
Michael Yount
Mustang Master
Apr 10, 2002
9,039
Charlotte, NC
Jul 8, 2005
  • Jul 8, 2005
I wouldn't use one -- a standard graphite composite exhaust gasket will work just fine IF the flanges are true. In fact, the ones I use (Ford dealer supplied for late model 5.0L Explorer) I've been able to re-use with no leaks -- I've had the right side header off, I don't know, 5 or 6 times over 3 years. Never a leak; never a loosening header bolt.
Remember - if the flanges aren't flat, not only are the bolts unequally stressed, the gasket takes a beating too.
I
Insane3D
310
#10
  • Jul 8, 2005
  • #10
I realize this, but my new FRPP headers with a thick flange came with .75" bolts. I ordered 1" long ones because I heard the FRPP headers came with longer bolts, and had to return them. I called the FRPP line, and they told me they did not recommend it, but it *may* work...
I know some people have no problem with them, but I prefer not to take the chance with the threads in my aluminum heads, and the stock length ARP stainless ones that only cost me $24 look great and work perfectly. Just my personal preference...
As for the Stage 8's, I'm guessing your car doesn't see winter? My Stage 8's heads were so rusted, I needed to soak them with PB blaster for a day because they had rusted to the header flange on my old POS BBK shorties. The were heavily rusted, and even if they "redesigned" them, unless they are stainless now, they will rust eventually..
I went with them years ago when I did my BBK headers, and those clips were very tedious to work with, and made a simple header swap much more time consuming, not to mention losing clips down in parts of the K member. Of course, Stage 8 doesn't give you any extra locks, so if you lose one or two, you are SOL unless you want to buy a new kit.
Anyway...just my experience and preference...to each his own.
Michael Yount
Mustang Master
Apr 10, 2002
9,039
Charlotte, NC
Jul 8, 2005
#11
  • Jul 8, 2005
  • #11
I too used ARP's stainless standard length fasteners with the small 8mm heads - work beautifully. There's PLENTY of thread to work with using .75" bolts even with thicker header flanges. I've got FRPP shorties on mine with the .75" ARP fasteners and aluminum heads - no problems.
FORCED2DV8
458
Grand Rapids MI
Jul 8, 2005
#12
  • Jul 8, 2005
  • #12
Another trick...
Yeah Want he said ! Plus safety wire looks good if you do it right.
Maryland Stang
1,656
30
39
Greenville, NC
Jul 8, 2005
#13
  • Jul 8, 2005
  • #13
It's all cool. That's part of the reason these and other forums exist. To debate. I don't take debates personally unless someone else get ugly. And no-one's getting ugly here.
The Stage 8s I have are the stainless version and the car doesn't get driven in the rain let alone snow.
The clips can be difficult but they do look cool when they are installed. I'm not in any hurries anyway and it's a weekend warrior car.
RYC CUKR
1,437
Orlando
Jul 8, 2005
#14
  • Jul 8, 2005
  • #14
A little pricey but seem pretty nice and no e clips to lose. they are the breslin split bolts ones part #bpp-200-077
http://store.summitracing.com/defau...earchinresults=false&N=0&target=egnsearch.asp
I have stage 8s on my 93 and they work great. It is true that they are kind of a pain because of having to mess with the e clips but its not like I swap heads or headers every month.
Forced Induction Prepping for supercharger on non-stock build
  • 91fox427
  • Nov 25, 2025
Fox 5.0 Mustang Tech Jan 5, 2026
Qtrhrse23
Most ridiculous / dishonest work you have heard a shop recommend?
  • SchwarzStock
  • Jul 19, 2026
  • Off-Topic Hangout
Off-Topic Hangout Jul 20, 2026
SchwarzStock
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
M
Engine Unexplainable Exhaust Pop and Gurgle
  • Mrnissen122
  • Feb 14, 2026
Fox 5.0 Mustang Tech Feb 18, 2026
Running very very rich
  • 2esoteric
  • Oct 31, 2025
Fox 5.0 Mustang Tech Oct 31, 2025
