Well I know you guys swear by them for our cars BUT what about my Ram? I'm getting a set of headers and summit has the bolts for like 42 bucks. I can't fathom why bolts are that expensive. Should I spend the money on them?
42 bux
Stainless Steel Lock Washers![]()
You can buy them for pennies at a bolt supply place![]()
Grady
Lock washers is what I also have and they work great NEVER had a loose bolt EVER!!!!![]()
... It a thought I wish a set of heads cost 40 bucks lolIts good to see someone else has saved a buck or two![]()
When you think about it
A few common sense things like this![]()
and
If you placed the bux saved in a hiding place
You just might could go first class with some of your mods![]()
Stud mount heads as opposed to Ped mount
Custom cam as opposed to ots
etc etc etc
I don't know... It a thought
Grady
I didn't use any washers, just tightened them down a couple of times after short runs.
Grady, I get your point about stud mounted head bolts as opposed to bolt style, but I've heard that removing our heads with studs is very hard to do. I'm pretty sure there's ways around it, like removing the studs closest to the firewall before pulling on the head. Also, I was told that we don't NEED studs until our combo is making crazy power, bolts will work just fine. What do you think?
I should have been more specific![]()
I was talking about type of rocker ... studs or pedestal
which
Would have a bearing on ones decision with aftermarket head selection
btw ... I did ARP head bolts for my NA combo![]()
Grady
