LOKAR E BRAKE CABLE
SB100
Is Lokar's Universal E Brake twin Cables compatible with a Mustg II/ Pinto type floor mounted hand brake? The Lokar Tech line said they didn't know. I believe Lokar wants me to buy their Floor Mounted Handbrake in addition to their cables. I figure at most I may have to drill the hole in the Mustang floor mounted hand brake adjusting bolt clevis larger to accept Lokar's adjusting bolt. Who knows. Thanks.
Lokar emergency brake
What car are you trying to mount this in?
THE CAR IS A 1936 540 kMBZ KIT CAR I dropped a 5.0/AOD into. Has '78 Mustg II power rack & steering with a 8" Ford 4-link drum rearend. The trans tunnel is very narrow and the cables will have to be mounted on their side on the passenger side of the tunnel. The rear driver cable will have to follow the pass side cable to the axle, and then loop over to the driver side drum. This full fram kit car was built in 1981 and used a '78 Mustg II a a donor car for almost everything except the sheetmetal.
