Long Tubes Headers and the Truth....
Got your attention with that title ehhhhh.
Okay, here is the skinny.
ALL OF YOU NEED LONG TUBES IF YOU DON'T HAVE THEM.
Yes- I have had shorties in the past on another car.................................
Got my car out on the road today for the first time.
WOWOWOWOWOWOWOWOWOWOWOWOWOWOWOWOW!!!!!!!!!!!!!!
Not only do they sound awesome, I went from 2 High flow cats to O/R H. Deffinate SOTP difference. It just howls. Nice idle, little soft on excelleration, then when you get to the upper RPM's, it just Roars..........
GO GET UM GUYS.............................LT
super302 said:
:rlaugh:
how bad was the install :shrug:
I did the install by myself. If I had a helper, it would have been much easier. I just took my time. It wasn't hard, it just requires patience. I did the engine lift thing for the passenger side. Wasn't hard. If you can do a brake job, you have what it takes to do this. Just take your time.
It also helps if you remove all the smog equipment, and have a set of ratcheting wrenches.
I think the hardest part was bending the dipstick tube into a configuration that was usable. I did it, just took a few trys. I also put on the lowering springs, and have gone over a few normal speed bums, and some steeper entrances. No scrapes yet. I just took them slow and at an angle.
I just love the howl. Puts a :D on my face....................LT
i just did an identical swap at the same time as loudtoy and i can tell you he isn't lying. I have a very noticable sotp feel and the things got rid of my drone from the dumps and it screams up top!!!!
I agree GET THEM!!
the install wasnt to bad. I also did it by myself the only thing i got help on was getting the h pipe into place.
also Loudtoy because of the crash i never got a reply from you on whether you ran the dipstick around all the tubes or through them.
Well I'll be getting my LT's as soon as I get your Dr. gas! :banana:
Humm wonder how that combo will sound :rolleyes:
1.bbk ceramic LT's
2.Dr. Gas X pipe
3.SLP catback
Sound like a screaming demon to me!
igotyofire said:
which ones did u get, and can u take me for a ride,lolz
Sorry Guys, been workin like crazy here. One of the Fast Attack Subs pulled in today, so I wanted to help out and see all my friends.
To answer your questions, BBK Ceramic LTs and BBK H(soon to be Ceramic). I see it was already answerd. Thanks for keepin up mootang, and I sent the dipstick tube between two primarys. I heat wrapped it, but you don't need to. I just had a little left from wrapping my starter. I just bent it creatively, and popped it back. After 100 miles, no issues yet. (knock on wood) And yes all, I put 100 miles on her these past few days. SHOCKED!!!!!!!!!
igotyofire, if you are in the San Diego area, sure, we can arange a ride. Alwasys lookin for fellow Mustang owners. Especially StangNeters. There is a show April 3rd close to here. Southwester University or something. It is on the West Coast forum. I am considering going if your interested.
95WhiteVenom - I am sure it will sound amazing. Everyone told me to get this unit, but as I said, my crossmember hangs down anbout 3/4" more than normal. It just wasn't gonna fit. The BBK unit came with enough of a bend to make it fit. I had to bend it a little more than it was, but it worked out. If you look at the site it my sig, you might see the bends I made.
LT
SWYZ721 said:
So you DID notice a little low end torque loss?
Not really. I am sure there was a little, but it is deffinatly made up in the upper RPM range. Seems like there is a little more room in first, and a little less in second. When you hit third, BIG difference.
LTs really aren't emissions legal in states that require the carb numbers like California here. I have my car registered as a collector car, so I will never have to worry about smog. Also, I don't even put 2000 miles a year on the car. You can pass the sniffer, but I would check around to be sure.
Personally, If I had to deal with smog, it would only be every other year. I deffinatly wouldn't have a problem doing a swap once every two years. I bought the car to work on it. It wasn't that hard that I wouldn't do it again, especially for the sound :D . Just my opinion........................LT
