Longer tie rods?
black93lx
24
IL.
I've got a '91 Lx and the tie rod ends are way too far out on the inner tie rods (just converted to 4 wheel disc with new k-member and new front suspension). I don't have very many threads left holding the passenger side outer tie rod end on.
Any thoughts here? can i get longer outer tie rod ends that will fit? or longer inner ones? or can i do something with how the rack is mounted? I've got a QA1 tubular k-member on. I'm planning on buying the offset rack bushings considering the tie rod ends are higher than the rack when the car is on the ground to adjust for that.
any help is appreciated.
