Longevity of Aluminum Heads
The Dan
319
Orange County, CA
I was wondering what the longevity of aluminum heads are? I know an engine will last longer if not "hot rodded" a lot, but are the aluminum heads expected to live as long a life as cast iron? I only ask becasue I've deceided to make my FB a daily driver and sell my F-150 Harley Supercrew, and I'd like to put a little more getty up under the hood. I've been spoiled by a supercharger! Anyways, I have a set of AFR's on the way, and don't know if I should hold off on the aluminum heads if they aren't going to do as well for daily driving. Opinions?
Thanks.
Well, my BMW has nearly 250,000 miles on it. I had to remove the head to replace a rocker arm, so I sent it to a machine shop. It only needed valve stem seals and a very small amount of milling. I see this same thing all of the time with aluminum head- cast iron blocks.
So, yes an aluminum head works just fine for longevity. The important thing is to not overheat it or it will warp.
-Dave
