Longtube Headers?
  • Thread starter Thread starter 1995stangman
  • Start date Start date Sep 5, 2011
  • 3
1 of 3 Next Last
1995stangman
36
  • Sep 5, 2011
I posted a thread a while back about which midpipe to purchase for my 1995 mustang. I decided to get the BBK o/r h pipe. then I looked at their longtube headers. right now I have my stock shorties and was woundering if the longtube headers are really worth the money. I have saved enough for the h pipe but was unsure about if i should save up and spend money on the headers.
alleymad95GT
204
Okemos, Michigan
Sep 6, 2011
  • Sep 6, 2011
Long tube headers will certainly outperform shorties...
But they can be a major PITA to put in. If you are doing the exhaust, I would recommend biting the bullet and spending the money and doing the extra work to put the longtubes in. It is worth it IMHO...
Of course, if you have an AODE, those headers won't fit anyhow...
1995stangman
36
  • Sep 6, 2011
BBK won't fit an auto?
VibrantRedGT
"STANGNET'S PENGUIN SMACKER"
424
154
Boca Raton, Florida
Sep 6, 2011
  • Sep 6, 2011
They do make LT's for Auto's but it will add lots of time on your install. The stock K-Member is pain to install LT's on a manual then add in the width of the auto tranny. Don't know what your mods are but if they are minimal I'd pass on LT's. Best time to install LT's is when your installing heads. At this point they would drop right in from the top plus give you more HP with the heads.
alleymad95GT
204
Okemos, Michigan
Sep 6, 2011
  • Sep 6, 2011
I do not believe that BBK Longtube headers will fit with an AODE.
I think MAC makes a set that will and Pacesetter says theirs will.
1995stangman
36
  • Sep 6, 2011
so my first step should be investing in some new heads. then LT.
Chern_889
86
Lumsden, Saskatchewan
Sep 15, 2011
  • Sep 15, 2011
I dont see any problem putting LTs on a stock headed, minimal bolt-on car. You gotta start somewhere right? most people cant just throw 2 or 3grand at the car in one sitting for bolt-ons, you build your combo one piece at a time. Once you do decide to put aluminum heads on it, you will already have the LTs, one less thing to buy at that time, your not gonna put stock headers back on a new alum head. just my .02
Bosko5.0
1,067
longwood, FL
Sep 15, 2011
  • Sep 15, 2011
Ive got bbk longtubes with my auto, tight fit. the O2's need to be relocated to the out side.
revhead347
Apparently my ex-husband made that mistake.
20+ Year Stangneter
Jun 14, 2004
9,303
1,649
214
Acworth, GA
Sep 16, 2011
  • Sep 16, 2011
Longtubes are worth the money. It's a good bit of work to get them in, but still worth it. BBK recently added a number of part numbers to their line up. Call them and ask what headers you need. They have a good customer service department. There are a bunch of threads on this website on how to install longtubes.
Kurt
Dino Dino Bambino
1,673
90
79
Cyprus
Sep 16, 2011
#10
  • Sep 16, 2011
  • #10
I have the MAC 1-5/8" long tubes (part no. MAC-TF94015) and I used BBK O2 sensor harness extension wires (part no. BBK-1676). Installation wasn't too bad. The passenger side header slipped in from above and the driver's side header from below when the engine was disconnected from its mounts and jacked up a couple of inches. Didn't need to disconnect the steering shaft but the oil dipstick tube did need to be bent forwards.
The headers fitted nicely but since the passenger side header runs very close to the starter, I insulated the starter with a DEI Starter Versashield. It's worked very well so far.
1995stangman
36
#11
  • Sep 16, 2011
  • #11
I looked up BBK h pipes and they don't make shorty h pipes to fit thier LT for my year.(1995). i have heard that mac makes good LT's, does thier short h pipes fit well?
Dino Dino Bambino
1,673
90
79
Cyprus
Sep 17, 2011
#12
  • Sep 17, 2011
  • #12
I had my stock H-pipe shortened to fit my long tubes and all 4 cats are gone.
99FiveOh
2,051
20
99
J-Ville, FL
Sep 17, 2011
#13
  • Sep 17, 2011
  • #13
Why would you pay all that money and do all that work for a sweet set of long tubes and route them into the tiny a$$ stock h pipe?
FastDriver
I was uncomfortably high & wearing a helmet
SN Certified Technician
Sep 5, 2001
6,241
2,949
224
Vass, NC
Sep 17, 2011
#14
  • Sep 17, 2011
  • #14
BBKs slipped right in from the bottom without issue for me. I really don't know what everyone is complaining about on the installation.
revhead347
20+ Year Stangneter
Jun 14, 2004
9,303
1,649
214
Acworth, GA
Sep 17, 2011
#15
  • Sep 17, 2011
  • #15
Probably didn't order the H-pipe with the longtubes and it was a lot to ship an H pipe to his location.
Kurt
Dino Dino Bambino
1,673
90
79
Cyprus
Sep 18, 2011
#16
  • Sep 18, 2011
  • #16
Exactly. Labour's cheap over here so it didn't cost me much to modify the stock H-pipe, and most of it has new 2.5" sections.
1995stangman
36
#17
  • Sep 21, 2011
  • #17
alright thanks guys. i might just get the o/r h for now, don't really have the money for the pipe and LT's. later on though would i have any trouble just fitting my LT's to the h pipe? or would i need to buy another separate pipe to put on?
W
woody6799
#18
  • Sep 22, 2011
  • #18
Long Tube headers need a h or x pipe for long tubes, shorties use one for shorties, if you change in the future you will need to buy a new h or X pipe.
StangRider1
45
Vancouver, Washington
Sep 26, 2011
#19
  • Sep 26, 2011
  • #19
Why an h-pipe?
For just a little more money, you can get an x-pipe that'll flow better than your h-pipe could. Personally, that's what I plan on doing.
revhead347
20+ Year Stangneter
Jun 14, 2004
9,303
1,649
214
Acworth, GA
Sep 26, 2011
#20
  • Sep 26, 2011
  • #20
Don't get that one started again.
Kurt
  • 3
1 of 3 Next Last
J
Low RPM jerking
  • Justinkins
  • Jul 8, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 11, 2026
fasterthangas
F
Engine Would you replace these OEM motor mounts?
  • 91GTstroked
  • Sep 21, 2026
Fox 5.0 Mustang Tech Oct 11, 2026
Potomus Pete
W
Helpful information for O2 sensors and Longtube headers
  • Warhorse85
  • Aug 16, 2025
1996 - 2004 SN95 Mustang -General/Talk- Aug 16, 2025
Warhorse85
W
Surging/stalling! problem or tune?
  • djj62478
  • Oct 4, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 14, 2026
KRUISR
G
Exhaust
  • GoldenRuleClassics
  • Apr 21, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 21, 2025
2000xp8
