  • SN95 4.6L Mustang Tech
Looking at 4.10 gears
  • Thread starter Thread starter georgio440
  • Start date Start date Nov 28, 2007
First Prev 2 of 2
fobra559
At least it's more erect and not floppy anymore.
Nov 1, 2007
721
Lindsay, CA
Nov 29, 2007
#21
  • Nov 29, 2007
  • #21
georgio440 said:
Do I really need new bearings and seals? My car only has ~65k miles on it.
It's recommended. I would most def do it if your car has 65k on it. It will save you the trouble down the road.
KronicRacer
502
puttering around Ft Lauderdale, FL
Nov 29, 2007
#22
  • Nov 29, 2007
  • #22
georgio440
195
Walnut Creek, CA
Nov 29, 2007
#23
  • Nov 29, 2007
  • #23
Ah, alright. It's gonna be a little more than $500, then.
fobra559
Nov 1, 2007
721
Lindsay, CA
Nov 29, 2007
#24
  • Nov 29, 2007
  • #24
Gears $180, Master Bearing Kit $100, SCT Tuner $300 Labor $250, Feeling the Butt Dyno with these mods...Priceless
georgio440
195
Walnut Creek, CA
Nov 29, 2007
#25
  • Nov 29, 2007
  • #25
Gears for $180? The cheapester FRPP 4.10s I've found are about $240.
fobra559
Nov 1, 2007
721
Lindsay, CA
Nov 29, 2007
#26
  • Nov 29, 2007
  • #26
Oops my bad, I was thinking 3.73's Where did you find the FRPP 4.10's at?
georgio440
195
Walnut Creek, CA
Nov 29, 2007
#27
  • Nov 29, 2007
  • #27
Americanmuscle.com
fobra559
Nov 1, 2007
721
Lindsay, CA
Nov 29, 2007
#28
  • Nov 29, 2007
  • #28
georgio440 said:
Americanmuscle.com
Check your PM.
BurningRubber
1,865
24
58
Nov 29, 2007
#29
  • Nov 29, 2007
  • #29
If you DONT want to invest in a tuner for almost $400 (or buy one used if you can), then a SpeedCal will do the trick and costs $100. However, if you want a tuner for the future go ahead and get one, kill 2 rhino's with 1 monkey.
fobra559
Nov 1, 2007
721
Lindsay, CA
Nov 29, 2007
#30
  • Nov 29, 2007
  • #30
:Word:
georgio440
195
Walnut Creek, CA
Nov 29, 2007
#31
  • Nov 29, 2007
  • #31
Yeah, I'll probably just go with SpeedCal since I'm kind of short on money right now. I can always do the full tune down the road. Then again, I could always just buy the tuner first, and get gears later when I have enough.
fobra559
Nov 1, 2007
721
Lindsay, CA
Nov 29, 2007
#32
  • Nov 29, 2007
  • #32
Yeah, it's better to have a tuner first and then the gears because I feel you on the budget situation
georgio440
195
Walnut Creek, CA
Nov 29, 2007
#33
  • Nov 29, 2007
  • #33
Would I know what to do with the tuner? I don't mind adjusting to a set-up that requires premium, since I already fill my car with that as it is. Also, with just the tuner, will I noticed a decent increase in performance?
BurningRubber
1,865
24
58
Nov 29, 2007
#34
  • Nov 29, 2007
  • #34
I got my Diablosport for $175, so deals are out there.
They are REAL easy to use, especially if it comes with instructions (if it doesnt PLEASE get some before you mess with any settings).
Yes they do make a difference in performance. By tweaking my timing and fuel I gained 6rwhp and 15lb ft of tourqe to the wheels as well.
Plus you can do data logging which is cool, adjust your fan settings, rev limiter, speed limiter, adjust gear ratios, turn off your rear o2's for an offroad mid pipe, and a couple of other sweet things... this is the Diablosport, others have the same basic features as well with some exceptions.
fobra559
Nov 1, 2007
721
Lindsay, CA
Nov 29, 2007
#35
  • Nov 29, 2007
  • #35
Oh Yeah! If you plan on getting an o/r pipe it will eliminate the need for mil's which will save you about $50.
And YES follow the instructions and you'll be fine.
georgio440
195
Walnut Creek, CA
Nov 29, 2007
#36
  • Nov 29, 2007
  • #36
This is the one I'm looking at:
http://www.americanmuscle.com/sct-x3-powerflash-tuner.html
Thoughts?
fobra559
Nov 1, 2007
721
Lindsay, CA
Nov 29, 2007
#37
  • Nov 29, 2007
  • #37
Sounds good to me.
First Prev 2 of 2
M
4.10 gears = 200,000 miles ?
  • michaelleewebb
  • Apr 1, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Apr 2, 2026
michaelleewebb
M
3.08 gears with a manual trans
  • limp
  • Aug 27, 2026
  • 2 3
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 14, 2026
Qtrhrse23
D
96 get convertible-sell or part out?
  • DTCstang
  • May 17, 2026
  • What is it Worth?!?!?
What is it Worth?!?!? May 18, 2026
nickyb
P
Air Fuel ratio bung location.
  • Praetorious
  • Feb 7, 2026
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 11, 2026
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
