Looking for 3.73
  • Thread starter Thread starter manpowermustang
  • Start date Start date Nov 23, 2004
M
manpowermustang
228
Milwaukee, Wi
Nov 23, 2004
  • Nov 23, 2004
Anyone got a set of 3.73 gears for sale in good condition?
willys1
1,004
New Jersey
Nov 23, 2004
  • Nov 23, 2004
Buy them new,,you can find them for 140!! By the time you buy them,and pay for shipping,youd be better off with a brand new set!! JMO
87'GTstang
1,025
  • Nov 23, 2004
Used gears are one thing that are a mistake by itself.
M
manpowermustang
228
Milwaukee, Wi
Nov 23, 2004
  • Nov 23, 2004
Thanks for the advice. I will take it. I was just triying to just change one thing on this car that does'nt or would cost over a hundred bucks like everthing else.
F
Flyin88LX
28
Colchester IL
Nov 24, 2004
  • Nov 24, 2004
I got mine at gefracing.com they were the cheapest I could find and their shipping is super fast.
87gtconv
ragtopman
2,595
Southern Calif
Nov 24, 2004
  • Nov 24, 2004
Look on eBay if you want to take a chance! I got mine and they look really nice. Have not installed yet, but they look good! Total cost for them was $94
R
raph130
517
  • Nov 24, 2004
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Nov 24, 2004
  • Nov 24, 2004
Do the T-Bird Turbo Coupe transplant...
Auto trans 87-88 Tbird Turbo Coupes come with 3.73 gears and manual Turbo Coupes come with 3.55 gears. I choose 3.55 since I do more highway driving. Both ratios have 10.5 disk brakes with vented rotors as standard equipment.
It takes 2 guys the first day to get the old rear end out and the new one bolted in place. It takes 1 guy another whole day to do the brakes.
You will need a several sets of fittings, I recommend that you get them from Matt90GT's website, http://www.svo73mm.cjb.net/. Read Matt's instructions thoroughly, everything you need to know about the brakes is all there. You need to be patient and follow all the internal links, and there are many of them. You will need 2 fittings in the rear to adapt your old brake tubing to the TC disk brakes. The fittings go between the steel tube and the caliper brake hose. You will need another set of fittings to make a 2 port to 3 port adapter. To make life simpler, just buy the kits from Matt. You could piece them together, but it's not worth the time unless you work at an auto parts store with all the fittings ever made.
You will need to drill the quad shock mounting holes 2” below the holes drilled for the Turbo Coupe mounting points. The bolts are metric, so don’t loose them or the nuts. A 15/32” drill should be about the right size unless you have access to metric sized drill bits. Going without quad shocks is not an option unless you have aftermarket parts to soak up the wheel hop.
You will need a proportioning valve, Summit has one for $40 + shipping.
You will need a kit (FMS makes the part) to gut the stock proportioning valve, Summit also has that, about $10.
You will need a new master cylinder, see Matt's site and make you choice. I used a 94-95 Mustang master cylinder. Note that rebuilt 94-95 Mustang master cylinders do not come with a reservoir. That means a trip to the junkyard and some more money spent.
Your brake pedal may be very hard and almost impossible to lock up the brakes. I had to replace the front calipers with 73 mm calipers from a 91 Lincoln Mark 8 to get the braking performance up to par.
Bleeding the brakes will require 2 people and some coordinated effort. I don’t recommend using you wife or girlfriend to pump the pedal – they get offended when you yell at them. I used a homemade power brake bleeder constructed from a garden sprayer and some fittings from Home Depot. It cost about $25 and was worth every penny.
See http://www.mustangcentral.net/tech/brake.html for help with the emergency brake - the stock setup tends to lock up and not release properly.
All in all I have been very pleased with the results.
MrKwik
1,008
Kansas City, Kansas
Nov 24, 2004
  • Nov 24, 2004
Another option is to get the TC rear out of an automatic car, swap in your drum brakes and axles from your existing rear if you dont care about the disc brakes. The advantage is that your new rear will be the same length that it was tto begin with. The TC housing is the same length as the stang rear but the axles are longer. And you can install it yourself rather than paying someone to install your gears. Unless of course you have the know how and equipment to do it yourself which most poeple dont. Its more labor intensive but if your strapped for cash, its a viable alternative. I have gotten TC rears for $100 before.
K
Digital Tuning Going heads/cam/intake. Do I need a tune?
  • karhoot
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 14, 2026
karhoot
K
Drivetrain Broken clutch cable- what it looks like
  • JulianR
  • Aug 6, 2026
Fox 5.0 Mustang Tech Aug 10, 2026
gkomo
K
Drivetrain '87 5.0 Installing New Ring Gear and Pinion - Pattern Questions
  • karhoot
  • Apr 23, 2026
Fox 5.0 Mustang Tech May 9, 2026
Mindseye007
T
1967 coupe gearing
  • TMVT
  • Nov 6, 2025
Classic Mustang Specific Tech Nov 6, 2025
D
What's it Worth? 2006 Mustang GT Convertable
  • doc0075579
  • Mar 2, 2026
  • What is it Worth?!?!?
What is it Worth?!?!? Mar 2, 2026
doc0075579
D
