LOOKING FOR 300RWHP PLEASE HELP!!!
  • Thread starter Thread starter lxwants12's
  • Start date Start date Oct 6, 2004
lxwants12's
506
  • Oct 6, 2004
HEY GUYS I DYNOED MY CAR AND GOT 286RWHP OTHER THEN A CHIP WHICH IM GONNA ORDER THIS WEEK...AND WITHOUT TAKING APART THE ENGINE TOO MUCH...WHAT ELSE CAN I ADD THE WILL GIVE ME THAT 14 RWHP I NEED...CAUSE IM DIEING FOR 12'S
STOCK 302 DOUBLE ROLLER TIMING CHAIN FROM FORD RACING, E 303 CAMSHAFT, TFS TWISTED WEDGE HEADS PORTED AND POLISHED ON BOTH THE INTAKE AND EXHAUST SIDE, 1.6 ROLLER ROCKERS FROM TRICK FLOW, HARDENED PUSHRODS FROM TRICKFLOW, TRICK FLOW STREET INTAKE, 70MM THROTTLE BODY AND EGR SPACER, GRANETLLI 75MM MAF SENSOR WITH FENDERWELL COLDAIR INTAKE SYSTEM, GRIFFEN RADIATOR, WITH ELECTRIC FANS, PULLEYS, BBK LONG TUBES WITH H PIPE WITH NO CATS, FLOWMASTER EXHAUST, HURST SHIFTER, KING COBRA CLUTCH, 3.73 GEARS, MSD COIL, MSD CAP AND ROTOR, MSD 6AL INGITON , FORD RACING 9MM WIRES, ADJUSTABLE FUEL PRESSURE REG., BBK 190 FUEL PUMP, RUNNIN 42 PSI OF FUEL,
C
casey4093
15
Gulfport, MS
Oct 6, 2004
  • Oct 6, 2004
what size injectors are you using?
super302
I'd do anything for free Bapples
May 29, 2004
2,878
Davenport, IA
Oct 6, 2004
  • Oct 6, 2004
didn't read all your mods, if you haven't done it yet, advance the timing and get a good tune up, with the chip it should be at 300!
houstonstangguy
979
Houston, Texas
Oct 6, 2004
  • Oct 6, 2004
your setup looks pretty good. I seriously doubt you will pick up 14rwhp with just the chip, but you could change cams or always port your intake which should get you there before the chip will.
Ninety_1_Notch
22
Indiana
Oct 7, 2004
  • Oct 7, 2004
I know you said you don't want to tear apart the engine too much, but the e cam is pretty out dated. Maybe going with a custom grind or even a tfs stage 1 will probably work better with your setup. However, my guess is you're probably in the 12's as it sits.
R
raph130
517
  • Oct 7, 2004
eliaseje
466
Ohio
Oct 7, 2004
  • Oct 7, 2004
defintely get a chip burnt...my buddy had one burnt for his stang and he made 30 RWHP.....on the dyno...
houstonstangguy
979
Houston, Texas
Oct 7, 2004
  • Oct 7, 2004
I am guessing it wasn't naturally aspirated though.
Legendary
1,925
City of Angels
Oct 7, 2004
  • Oct 7, 2004
What size font are you running?!?
J/K. I would go with a different cam to aid you to your goal.
Jo_885o
422
Clint. Twp, Michigan
Oct 7, 2004
#10
  • Oct 7, 2004
  • #10
his setup is similar to mine but without porting and i'm at the least expecting 300 w/ of course a dyno tune and all of that good stuff, and his heads are ported ummm......But i think ur 12's already also.
R
Rock777
195
Troy, IL
Nov 12, 2004
#11
  • Nov 12, 2004
  • #11
Jo_885o, what do you have your fuel pressure dialed in at?
T
tjm73
2,418
Rush, NY
Nov 12, 2004
#12
  • Nov 12, 2004
  • #12
Here is your plan...
1.) TF stage 2 (or custom) camshaft, then
2.) Customer computer tune
Don't buy an off the shelf chip. You'll be throwing money away you could buy a good cam with. Off the shelf chips are for stock or near stock setups and, IMO, junk. Custom chip for your setup =
GroverDill
GoldMember
5,442
1,490
214
Demotte IN 46310
Nov 12, 2004
#13
  • Nov 12, 2004
  • #13
I picked up 20 rwhp with just a custome dynot tune/chip
N/A
what_stanger?
I am the mailman!!
1,697
Northern Illinois
Nov 12, 2004
#14
  • Nov 12, 2004
  • #14
with 280 hp on the ground you should already be running 12s.
Forced Induction Prepping for supercharger on non-stock build
  • 91fox427
  • Nov 25, 2025
Fox 5.0 Mustang Tech Jan 5, 2026
Qtrhrse23
M
Engine Unexplainable Exhaust Pop and Gurgle
  • Mrnissen122
  • Feb 14, 2026
Fox 5.0 Mustang Tech Feb 18, 2026
  • dan50
  • Jul 18, 2026
dan50
R
please help 87 mustang megasquirt 2 idle problems
  • robbie5.0
  • Jun 2, 2025
  • Digital Self-tuning Forum
Digital Self-tuning Forum Jul 18, 2025
tate302
T
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
