looking for a good OFF THE SHELF nitrous cam
SAY GO
148
1992 Mustang LX Convertible
3:73 gear Eaton Posi
Stock Driveshaft
C4 "Performance Trans" Raybestos and fairbanks parts
3000 stall
306
Probe industries Crank
PI H rods
Ross Pistons
10:3:1 compression
AFR 185 58 cc heads
Trick flow Track heat intake
70mm TB
75mm MASS air
24 lb injectors
Mac CAI
Stock Fuel Lines
Stock fuel Pump
Tubular K-member
fiberglass hood
no smog/ac
Weld draglites 275/50/15 BFG's and 3.5 skinnies up front
Mac Shortie headers
h-pipe
dumped flowmasters
subframe connectors
im looking for a good off the shelf cam, so dont just say GO CUSTOM!!!1111 i know there will still probally be a few....but what would you recommend for a nitrous cam off the shelf...
Check out andersonfordmotorsport.com . They have a lot of cams that are as close to custom as you can go without actually buying a custom cam. I have one of their blower cams and it does the job really well.
