Looking for a retro/aftermarket part
  • Thread starter Thread starter GOvert
  • Start date Start date Dec 11, 2007
G
GOvert
495
101
63
north central Tennessee Valley
Dec 11, 2007
  • Dec 11, 2007
I was wondering if anyone has seen a part available for 65-6 Mustangs. I was looking at this pair of '87 spindles that I have and thought to myself how nice it would be to put them on a '65 without having to use the "Fatman" coilover kit to install them. It would be nice to have a bracket that would bolt in place of the strut and at the top of it bolt to the stock upper balljoint. Anyone seen anything like this ?
rbohm
6,698
550
204
tucson,az
Dec 11, 2007
  • Dec 11, 2007
check with factory five racing, they use that adapter on their kit cobra replica's.
bnickel
5,640
lubbock, texas
Dec 11, 2007
  • Dec 11, 2007
the problem is that you still end up with a front steer spindle.
G
GOvert
495
101
63
Dec 12, 2007
  • Dec 12, 2007
BINGO !
I knew I'd seen it somewhere...But, so far havn't found it on their site
http://factoryfive.com/
I'm needing a front steer setup because of a rear sump oil pan issue (Ford engine).
Thanks for the info guys !
bnickel
5,640
lubbock, texas
Dec 12, 2007
  • Dec 12, 2007
GOvert said:
BINGO !
it'd be a lot easier to change the oil pan wouldn't it?
G
GOvert
495
101
63
Dec 15, 2007
  • Dec 15, 2007
4.0 V-6 Ford engine
The mid '90's 4.0 and A4LD has a rear sump pan. I don't know of one with the front sump. As far as I know, By the '90's, pretty much all of the Ford engines were rear sump.
bnickel
5,640
lubbock, texas
Dec 15, 2007
  • Dec 15, 2007
the 4.0 v6 is a descendent of the old 2.8 v6 from the mercury capri and mustang II from the 70's. i think there was a front sump pan for one of those but can't remember for certain. if you can find one it might work
StangDreamin'
583
2nd Ocotillo bush east of the Colorado River; Sout
Dec 15, 2007
  • Dec 15, 2007
Which opens you to seemingly " a whole world"[i/] of R&P possibilities
This might be where he's going......
D
D.Hearne
11,730
south louisiana
Dec 16, 2007
  • Dec 16, 2007
Is it not possible to swap sides with the spindles to make em rear steer ? Just a thought.
wicked93gs
1,198
229
93
Nashville TN
Dec 16, 2007
#10
  • Dec 16, 2007
  • #10
I already looked into that, it throws the ackerman 45 degrees or more off, I dont think the car would be driveable if you did(although presumably with a 1.75" UCA drop you could use mustang II spindles which are front steer)
G
GOvert
495
101
63
Dec 17, 2007
#11
  • Dec 17, 2007
  • #11
Ackerman angle was my concern on swapping spindles. M II is the back-up plan and was aware that I would have to lower the UCA's. I am using a fox body rearend so the wheel pattern is the same. Plotting the access hole through the lefthand shock tower brace for steering column access shouldn't be too difficult. I thought if a bracket could be made to use the fox body spindles would be great because they are in fairly abundant supply. I made a rough drawing this weekend for the part and a jig to "reverse engineer" the part. I'll let ya'll know how thst goes. In the meantime I'll use the M II spindles. I think the rotors are just a little smaller than Fox and use the M II wheel cyl diminsions, pro valve and MC and it all should work OK. Thanks for the input !
M
Air Conditioning parts source
  • mustangmark68
  • Jul 1, 2025
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Jul 1, 2025
mustangmark68
M
A
Discussion on mild budget build/ top end
  • Acesario
  • Feb 21, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 23, 2026
General karthief
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
R
  • riored97snake
  • Jun 18, 2026
  • What is it Worth?!?!?
riored97snake
R
SN95 Desktop 363 Engine Combination - Looking for input
  • WhiteCobra95
  • Sep 8, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 6, 2025
Habu135
