Looking for electric fan...
  • Thread starter Thread starter PhLoBuS
  • Start date Start date Nov 7, 2004
1 of 2 Next Last
PhLoBuS
473
Beverly, MA
Nov 7, 2004
  • Nov 7, 2004
I want to get rid of my stock fan and want to go with an electric one since I am getting robbed a few HP with my current one. What should I go with and whats a good site/place to get it from? I am looking for a new one or fairly new one that is in great condition, have any ideas paste them here!
PNY PWR
522
Wichita, KS
Nov 7, 2004
  • Nov 7, 2004
SN95, Taurus, Black Magic, Proform to start off
HISSIN50
34
129
Nov 7, 2004
  • Nov 7, 2004
and a www.DcControl.com unit to control it.
what alternator upgrade do you have?
dont forget the Mark 8 fan, if you want overkill.
good luck.
10HoleLX
257
Southern California
Nov 7, 2004
  • Nov 7, 2004
Black Majic through SUMMIT RACING. Factory looking easy to read and understand installation guide provided.
L
L8 MUSL
1,664
Carlsbad, Ca.
Nov 7, 2004
  • Nov 7, 2004
The Black Magic is weak, but do a search.
This topic has been addressed extensively.
Michael Yount
Mustang Master
Apr 10, 2002
9,039
Charlotte, NC
Nov 7, 2004
  • Nov 7, 2004
You won't hear people complain about Lincoln MkViii, SN95, Taurus 3.8L fans, the dual 11" SPAL fully shrouded units. As mentioned above, if you want to take full advantage of the benefit of the electric - control it with a DC Control unit; you can get the fan through them too.
281pony
2,681
Oly, WA
Nov 7, 2004
  • Nov 7, 2004
sorry to jump in here.
i tried the proform electric fan a couple weeks ago with roughly 280 crank hp and it wasnt cooling as well as my stock fan. normally i run at 165 on a 60 degree day with no heat on driving normal for example. with the proform it was at 180 driving normal in 45 degree weather, with the heat on.
im looking for something that can provide sufficient cooling for roughly 500 hp now, is a better option besides the fans dc sells? im thinking a dual fan setup, where is the best place to look into those?
$340 seems like quite abit for one of their fans, but maybe im way off base?
Michael Yount
Mustang Master
Apr 10, 2002
9,039
Charlotte, NC
Nov 7, 2004
  • Nov 7, 2004
www.spal-usa.com -- they have a dealer listing.
If you want to get serious about moving enough air across the rad to keep high output motors cool, it takes a lot of quality fan. As for the cost - think of what overheating that 500HP mill will cost you. Don't try to skimp on the cost of the fan.
AND - shop around; most score the Ford fans from the junk yard at relatively low cost - but, of course, they're used.
I use the twin 11" fully shrouded SPAL set up on mine with the DC controller and it has performed flawlessly. If you'd like to see some pics email me at myount@senndelaney.com. Here's a bit more about the install -- http://www.etnracing.com/pages/Tech/FanControl.htm
Michael Yount
Mustang Master
Apr 10, 2002
9,039
Charlotte, NC
Nov 7, 2004
  • Nov 7, 2004
Oh - only you can decide what the best value is for you, but the price you mentioned includes the "big" fan and the control system all mounted and ready to install....
281pony
2,681
Oly, WA
Nov 7, 2004
#10
  • Nov 7, 2004
  • #10
thanks for the information.
yeah i definately dont want to halfass my cooling, i was moreless curious of the best cooling options. $340 is quite abit still compared to what i was looking at before, like the proform fan was 120 shipped i think.
ill send you an email about the fans, that looks like what i was going for with the two fan setup also.
NosPony
278
Canton, Il
Nov 7, 2004
#11
  • Nov 7, 2004
  • #11
i as going with the summit s-blade fan i think it is 85 bucks. It moves over 2000 cfm. Just a power wire on a a toggle switch.
281pony
2,681
Oly, WA
Nov 7, 2004
#12
  • Nov 7, 2004
  • #12
yeah, thats what the specs/install of the proform was like. it was a really well designed fan, but it had hp support numbers which i was over. couldnt expect too much from a 90 dollar fan though.
btw, im building a similar combo to you with the 306 and edelbrock intake, what heads are you running? how do you like it?
in a couple months im going to run some boost too.
mustangdaren
605
Hildebran, North Carolina
Nov 7, 2004
#13
  • Nov 7, 2004
  • #13
I have a ramchargers fan on mine and it works great. It is a dual fan with a high and low speed.
C
crunchie12268
599
Manhattan, KS
Nov 7, 2004
#14
  • Nov 7, 2004
  • #14
I have the 3.8L Ford Taurus fan that I had in my 88GT and it worked great. I took it out to put in my car now. They work great, it worked on my friends 89 GT with a Vortech Supercharger and kept it nice and cool. I will sell you mine for 40 bucks, and I will give you the maxi fuse and wiring. You would just have to buy the relay at autozone or something.... their like 5 bucks. Easy to install, did it in 2 hours and I could feel a little difference. Also they are good on track days.
PhLoBuS
473
Beverly, MA
Nov 7, 2004
#15
  • Nov 7, 2004
  • #15
crunchie any pictures?? send me a private message!
PhLoBuS
473
Beverly, MA
Nov 7, 2004
#16
  • Nov 7, 2004
  • #16
Anyone know the cfm on the taurus fan?
HISSIN50
34
129
Nov 7, 2004
#17
  • Nov 7, 2004
  • #17
my take on fans. if one is going to spend a couple hundred (or more) on the setup, i would:
not get a new fan. get a J/Y fan (any mentioned - SN, 3.8 taurus, cougar, Mark 8, et al). for cheap at the J/Y. then spend the rest of the money on a Dc Controller. the controller will make the fan be much more efficient than old school switches and relays. let alone, from what Michael has said, one can get by with less alternator output with this controller (since it is variable). one still should have a 3G type upgrade, but 130 amps is not necessarily needed, depending upon other system draws and mods (stereo, etc).
my two cents. good luck.
BTW, i dont have any of this stuff - but i know what i would do if i were to.
bossmstng302
52
phoenix, arizona
Nov 7, 2004
#18
  • Nov 7, 2004
  • #18
mike-
i am really liking DC Control's 18' kit with everything integrated. just VERY simple wire up if you look at it. the flow numbers seems very good to. i am running a novi blown 347 right now but still have my stock fan/clutch assemble with a fluidyne radiator. my question is, would their 18' kit be enough for my current setup or should i look into their control unit with another type like spal or something. any opinions from ANY of you guys would be greatly appreciated. i live in AZ were cooling is a major issue. thanks again!
R
ratrapp
510
buena vista,va
Nov 7, 2004
#19
  • Nov 7, 2004
  • #19
i don't know why everyone knocks the proform fan.i've had mine for a year and a half and it performs flawlessly.theres not a product on the market that somebody's not going to have a had a bad experience with.no the proform isn't going to cool a 500hp motor,it's not meant to.it will cool the average 300 or so hp stangs.it all depends on application.
Michael Yount
Mustang Master
Apr 10, 2002
9,039
Charlotte, NC
Nov 7, 2004
#20
  • Nov 7, 2004
  • #20
bossmstng - I'd ask your questions directly of DC Control - you can reach them by email at support@dccontrol.com.
1 of 2 Next Last
Resolved Wiring electric fan
  • cbac89
  • Aug 29, 2026
cbac89
Engine Standard or hi flow water pump?
  • AnthonyA1234
  • Sep 28, 2026
Fox 5.0 Mustang Tech Oct 9, 2026
2000xp8
Engine Themostat
  • Mindseye007
  • Jan 30, 2026
Fox 5.0 Mustang Tech Feb 1, 2026
86HO5.0
Who Is Up To Date On DCC Fan Controllers?
  • BoostedRed89gt
  • Jun 15, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 26, 2026
revhead347
Foxbody high rpms and surging rpms
  • 86foxseth
  • Jun 9, 2026
Fox 5.0 Mustang Tech Jun 13, 2026
