Looking for H/C/I combos using AFR's
I was seriously thinking about the trickflow kit but now Iam also considering a combo using AFR's. I heard the 165's with a perfromer intake works well but what cam should I use? I will also be running 8-10 psi....and aiming for 410+ rwhp. Thanks guys!
if the engine is supercharged i will run 185's with the performer and comp cams camshaft special for blower or turbo grind 276H-R14 (part#35-312-8) or (#35-556-8).......
AFR 165's would be a good choice because you wouldn't have to notch the pistons (or change them out) and weaken the stock pistons. They will still flow fine and you could shoot for 450rwhp:nice:
I have afr 165's and a Performer intake. I would ge the performer rpm for a bit better flow for the blower.
Good Luck with that:)
