Looking For Help With A 91 Code
Ive been dealing with this sporatically over 4 years and have been into the motor top end three times as well as one rebuild two years ago. Last time i ran the KOER test it was not there ... but who knows. Even had injectors flowed n balanced. Though it may show up at a later date, I'm kinda leaning towards the computer/ air injection during the particular test because sometimes it shows other times it does not. Since all the air is dumped to the drivers head mostly (straight path as opposed to 90 degree bend for passenger head) and the age of things ... the accuracy may just not be there when new. I have done everything listed and checked EVERYTHING ever mentioned and nothing really was found. possibly its testing it too soon after the battery was disconnected. Does not seem to show up the hotter the car is, the longer it has run or the longer since disconnecting the battery. Only have had it show up in the KOER test not in Continious Memory. Ive checked everything from top to bottom multiple times. I did find that the header to H-pipe was leaking both sides w compressed air up tailpipes but passenger side was leaking worse and no code over there ... didn't like any leaking but like I was told, these connections are not exactly air tight no matter what people want to believe and my bolts/nuts are quite tight and components are new ... so not much can be done there.I haven't pulled car out yet for this season but will be keeping an eye on it as always the last couple of years. It has literally wore me out emotionally/physically dealing with crap parts that are flooding the market ... then ya gotta find more problems. I have it pretty good now after finding two flaws in my supercharger manifolds that were addressed by Kenne Bell that no one told me about ... what a bad joke.
I don't know if that's a relief to hear or more of a headache.
I got the car started (had to rotate the dizzy clockwise a lot, don't know WHAT happen to the timing!). Didn't have a timing gun handy, but set idle to 600 rpm spout out (about 750 rpm with spout in). Then I got it nice and warm and dribbled oil around the base of the drivers side injectors, one at a time. I didn't hear any difference in idle.
I cleared the codes, ran the test and the 91 is gone.
BUT, now I have a 44 and a 33! Double and triple checked all the vacuum lines, and they were all good. Cleared codes, reran test and still got 44 and 33.
Let me clarify about the 44 and 33....
After I dribbled the oil, I cleared the codes and ran a KOER. Then I got a 44. Then I double and triple checked all the smog vacuum lines, cleared the codes again, and reran the KOER. Then I got a 44 and a 33. So, the more I try to repair it, the worse it gets.
One more thing... I think you can ignore the 33, because I don't remember hooking the vacuum line back up to the EGR. I'll double check on that in the morning.
But that still leaves the 44.
Code 33 - Insufficient EGR flow detected.
Look for vacuum leaks, cracked vacuum lines, failed EGR vacuum regulator. Check to see if you have 10” of vacuum at the EGR vacuum connection coming from the intake manifold. Look for electrical signal at the vacuum regulator solenoid valves located on the rear of the passenger side wheel well. Using a test light across the electrical connector, it should flicker as the electrical signal changes. Remember that the computer does not source any power, but provides the ground necessary to complete the circuit. That means one side of the circuit will always be hot, and the other side will go to ground or below 1 volt as the computer switches on that circuit.
Check for resistance between the brown/lt green wire on the EGR sensor and pin 27 on the computer: you should have less than 1.5 ohm.
Backside view of the computer wiring connector:
a9x-series-computer-connector-wire-side-view-gif.71316
See the following website for some help from Tmoss (diagram designer) & Stang&2Birds (website host)
http://www.veryuseful.com/mustang/tech/engine/images/88-91eecPinout.gif
EGR test procedure courtesy of cjones
to check the EGR valve:
bring the engine to normal temp.
connect a vacuum pump to the EGR Valve or see the EGR test jig drawing below. Connnect the test jig or to directly to manifold vacuum.
Do not connect the EGR test jig to the EVR (Electronic Vacuum Regulator).
apply 5in vacuum to the valve. Using the test jig, use your finger to vary the vacuum
if engine stumbled or died then EGR Valve and passage(there is a passageway through the heads and intake) are good.
if engine did NOT stumble or die then either the EGR Valve is bad and/or the passage is blocked.
if engine stumbled, connect EGR test jig to the hose coming off of the EGR Valve.
Use your finger to cap the open port on the vacuum tee.
snap throttle to 2500 RPM (remember snap the throttle don't hold it there).
did the vacuum gauge show about 2-5 in vacuum?
if not the EVR has failed
EGR test jig
egr-test-jig-gif.58022
The operation of the EGR vacuum regulator can be checked by using a test light applied across the wiring connector. Jumper the computer into self test mode and turn the key on but do not start the engine. You will hear all the actuators (including the EVR vacuum regulator) cycle. Watch for the light to flicker: that means the computer has signaled the EGR vacuum regulator successfully.
Leaks or problems with the Thermactor air system can allow excess air into the exhaust system and set an O2 sensor code. The Thermactor air adds air to the exhaust stream before the O2 sensors. This occurs in the cold start mode when the engine is first warmed up.
Three possibilities for this symptom:
1.) If that process fails to shut off after the engine has reached operating temperature, it could set an O2 sensor code since the engine is getting more air.
2.) If the crossover passages in the RH side (code 44) is blocked, then all the air is forced through the LH side. That could set your 91 code.
3.) Combination of 1 & 2 above.
Thermactor Air System
Some review of how it works...
Revised 17-Sept-2011 to add testing procedure.
The Thermactor air pump (smog pump) supplies air to the heads or catalytic converters. This air helps break down the excess HC (hydrocarbons) and CO (carbon monoxide). The air supplied to the catalytic converters helps create the catalytic reaction that changes the HC & CO into CO2 and water vapor. Catalytic converters on 5.0 Mustangs are designed to use the extra air provided by the smog pump. Without the extra air, the catalytic converters will clog and fail.
The Thermactor air pump draws air from an inlet filter in the front of the pump. The smog pump puts air into the heads when the engine is cold and then into the catalytic converters when it is warm. The Thermactor control valves serve to direct the flow. The first valve, TAB (Thermactor Air Bypass) or AM1 valve) either dumps air to the atmosphere or passes it on to the second valve. The second valve, TAD (Thermactor Air Diverter valve or AM2 valve) directs it to the heads or the catalytic converters. Check valves located after the TAB & TAD solenoids prevent hot exhaust gases from damaging the control valves or pump in case of a backfire. The air serves to help consume any unburned hydrocarbons by supplying extra oxygen to the catalytic process. The computer tells the Thermactor Air System to open the Bypass valve at WOT (wide open throttle) minimizing engine drag. This dumps the pump's output to the atmosphere, and reduces the parasitic drag caused by the smog pump to about 2-4 HP at WOT. The Bypass valve also opens during deceleration to reduce or prevent backfires.
Code 44 RH side air not functioning.
Code 94 LH side air not functioning.
The computer uses the change in the O2 sensor readings to detect operation of the Thermactor control valves. When the dump valve opens, it reduces the O2 readings in the exhaust system. Then it closes the dump valve and the O2 readings increase. By toggling the dump valve (TAB), the computer tests for the 44/94 codes.
Failure mode is usually due to a clogged air crossover tube, where one or both sides of the tube clog with carbon. The air crossover tube mounts on the back of the cylinder heads and supplies air to each of the Thermactor air passages cast into the cylinder heads. When the heads do not get the proper air delivery, they set codes 44 & 94, depending on which passage is clogged. It is possible to get both 44 & 94, which would suggest that the air pump or control valves are not working correctly, or the crossover tube is full of carbon or missing.
thermactor-air-system-65-gif.50636
Computer operation & control for the Thermactor Air System
Automobile computers use current sink technology. They do not source power to any relay, solenoid or actuator like the IAC, fuel pump relay, or fuel injectors. Instead the computer provides a ground path for the positive battery voltage to get back to the battery negative terminal. That flow of power from positive to negative is what provides the energy to make the IAC, fuel pump relay, or fuel injectors work. No ground provided by the computer, then the actuators and relays don't operate.
One side of the any relay/actuator/solenoid in the engine compartment will be connected to a red wire that has 12-14 volts anytime the ignition switch is in the run position. The other side will have 12-14 volts when the relay/actuator/solenoid isn't turned on. Once the computer turns on the clamp side, the voltage on the computer side of the wire will drop down to 1 volt or less.
In order to test the TAD/TAB solenoids, you need to ground the white/red wire on the TAB solenoid or the light green/black wire on the TAD solenoid.
For 94-95 cars: the colors are different. The White/Red wire (TAB control) is White/Orange (Pin 31 on the PCM). The Green/Black wire (TAD control) should be Brown (pin 34 at the PCM). Thanks to HISSIN50 for this tip.
Testing the system:
To test the computer, you can use a test light across the TAB or TAD wiring connectors and dump the codes. When you dump the codes, the computer does a self test that toggles every relay/actuator/solenoid on and off. When this happens, the test light will flicker.
Disconnect the big hose from smog pump: with the engine running you should feel air output. Reconnect the smog pump hose & apply vacuum to the first vacuum controlled valve: Its purpose is to either dump the pump's output to the atmosphere or pass it to the next valve.
The next vacuum controlled valve directs the air to either the cylinder heads when the engine is cold or to the catalytic converter when the engine is warm. Disconnect the big hoses from the back side of the vacuum controlled valve and start the engine. Apply vacuum to the valve and see if the airflow changes from one hose to the next.
The two electrical controlled vacuum valves mounted on the rear of the passenger side wheel well turn the vacuum on & off under computer control. Check to see that both valves have +12 volts on the red wire. Then ground the white/red wire and the first solenoid should open and pass vacuum. Do the same thing to the light green/black wire on the second solenoid and it should open and pass vacuum.
Remember that the computer does not source power for any actuator or relay, but provides the ground necessary to complete the circuit. That means one side of the circuit will always be hot, and the other side will go to ground or below 1 volt as the computer switches on that circuit.
The computer provides the ground to complete the circuit to power the solenoid valve that turns the
vacuum on or off. The computer is located under the passenger side kick panel. Remove the kick panel & the cover over the computer wiring connector pins. Check Pin 38 Solenoid valve #1 that provides vacuum to the first Thermactor control valve for a switch from 12-14 volts to 1 volt or less. Do the same with pin 32 solenoid valve #2 that provides vacuum to the second Thermactor control valve. Starting the engine with the computer jumpered to self test mode will cause all the actuators to toggle on and off. If after doing this and you see no switching of the voltage on and off, you can start testing the wiring for shorts to ground and broken wiring. An Ohm check to ground with the computer connector disconnected & the solenoid valves disconnected should show open circuit between the pin 32 and ground and again on pin 38 and ground. In like manner, there should be less than 1 ohm between pin 32 and solenoid valve #2 and pin 38 & Solenoid valve #1.
If after checking the resistance of the wiring & you are sure that there are no wiring faults, start looking at the solenoid valves. If you disconnect them, you can jumper power & ground to them to verify operation. Power & ground supplied should turn on the vacuum flow, remove either one and the vacuum should stop flowing.
Typical resistance of the solenoid valves is in the range of 20-70 Ohms.
Theory of operation:
Catalytic converters consist of two different types of catalysts: Reduction and Oxidation.
The Reduction catalyst is the first converter in a 5.0 Mustang, and the Oxidation converter is the second converter. The Oxidation converter uses the extra air from the smog pump to burn the excess HC. Aftermarket converters that use the smog pump often combine both types of catalysts in one housing. Since all catalytic reactions depend on heat to happen, catalytic converters do not work as efficiently with long tube headers. The extra length of the long tubes reduces the heat available to operate the O2 sensors and the catalytic converters. That will cause emissions problems, and reduce the chances of passing an actual smog test.
Now for the Chemistry...
"The reduction catalyst is the first stage of the catalytic converter. It uses platinum and rhodium to help reduce the NOx emissions. When an NO or NO2 molecule contacts the catalyst, the catalyst rips the nitrogen atom out of the molecule and holds on to it, freeing the oxygen in the form of O2. The nitrogen atoms bond with other nitrogen atoms that are also stuck to the catalyst, forming N2. For example:
2NO => N2 + O2 or 2NO2 => N2 + 2O2
The oxidation catalyst is the second stage of the catalytic converter. It reduces the unburned hydrocarbons and carbon monoxide by burning (oxidizing) them over a platinum and palladium catalyst. This catalyst aids the reaction of the CO and hydrocarbons with the remaining oxygen in the exhaust gas. For example:
2CO + O2 => 2CO2
There are two main types of structures used in catalytic converters -- honeycomb and ceramic beads. Most cars today use a honeycomb structure." Quote courtesy of How Stuff Works (HowStuffWorks "Catalysts")
What happens when there is no extra air from the smog pump...
As engines age, the quality of tune decreases and wear causes them to burn oil. We have all seem cars that go down the road puffing blue or black smoke from the tailpipe. Oil consumption and poor tune increase the amount of HC the oxidation catalyst has to deal with. The excess HC that the converters cannot oxidize due to lack of extra air becomes a crusty coating inside the honeycomb structure. This effectively reduces the size of the honeycomb passageways and builds up thicker over time and mileage. Continuous usage under such conditions will cause the converter to fail and clog. The extra air provided by the Thermactor Air System (smog pump) is essential for the oxidation process. It oxidizes the added HC from oil consumption and poor tune and keeps the HC levels within acceptable limits.
Newer catalytic converters do not use the Thermactor Air System (smog pump) because they are designed to work with an improved computer system that runs leaner and cleaner
They add an extra set of O2 sensors after the catalytic converters to monitor the oxygen and HC levels. Using this additional information, the improved computer system adjusts the air/fuel mixture for cleaner combustion and reduced emissions. If the computer cannot compensate for the added load of emissions due to wear and poor tune, the catalytic converters will eventually fail and clog. The periodic checks (smog inspections) are supposed to help owners keep track of problems and get them repaired. Use them on an 86-95 Mustang and you will slowly kill them with the pollutants that they are not designed to deal with.
Codes 44 & 94 - AIR system inoperative - Air Injection. Check vacuum lines for leaks, & cracks. Check for a clogged air crossover tube, where one or both sides of the tube clog with carbon.
attachment.php
Revised 21 Sep 2012 to correct the description of the process that sets the code and include Thermactor Air System diagram.
If you have a catalytic converter H pipe, you need to fix these codes. If you don't, then don't worry about them.
The TAD solenoid/TAD diverter valve directs smog pump output to either the crossover tube attached to the cylinder heads or to the catalytic converters.
The O2 sensors are placed before the catalytic converters, so they do not see the extra O2 when the smog pump's output is directed to the converters or the input just before the converter.
The 44/94 code uses the O2 sensors to detect a shift in the O2 level in the exhaust. The smog pump provides extra air to the exhaust which raises the O2 level in the exhaust when the smog pump output is directed through the crossover tube.
When there is an absence of increase in the O2 levels when the TAD solenoid/TAD diverter valve directs air through the crossover tube, it detects the lower O2 level and sets the code.
Testing the system:
Note that the engine must be running to do the tests unless stated otherwise. For safety’s sake, do test preparation like loosening clamps, disconnecting hoses and connecting things to a vacuum source with the engine off.
The following computer tests are done with the engine not running.
vacuum on or off. The computer is located under the passenger side kick panel. Remove the kick panel & the cover over the computer wiring connector pins. Check Pin 38 Solenoid valve #1 that provides vacuum to the first Thermactor control valve for a switch from 12-14 volts to 1 volt or less. Do the same with pin 32 solenoid valve #2 that provides vacuum to the second Thermactor control valve. Turning the ignition to Run with the computer jumpered to self test mode will cause all the actuators to toggle on and off. If after doing this and you see no switching of the voltage on and off, you can start testing the wiring for shorts to ground and broken wiring. An Ohm check to ground with the computer connector disconnected & the solenoid valves disconnected should show open circuit between the pin 32 and ground and again on pin 38 and ground. In like manner, there should be less than 1 ohm between pin 32 and solenoid valve #2 and pin 38 & Solenoid valve #1.
The following computer tests are done with the engine running.
If after checking the resistance of the wiring & you are sure that there are no wiring faults, start looking at the solenoid valves. If you disconnect them, you can jumper power & ground to them to verify operation with the engine running. Power & ground supplied should turn on the vacuum flow, remove either one and the vacuum should stop flowing.
Got the balancer swapped out today. It wouldn't start unless I had the timing up to 30* btdc! It was running good (with the exception of the 91 code) until I pulled the coil lead and spun the motor over for a minute. (I did that to see if the balancer was wobbling, which it was.) I thought it was just flooded, but I ended up pulled each plug and none were covered with gas. The only way I got it to start before I pulled the old balancer off was to jack the timing way up.
Tonight, after replacing the balancer, and with the timing at 30* (because it wouldn't run at less than 30*) I reran codes. I got an 18 (duh) and the 91 is back. I replaced the pass side o2 sensor and the 44 is now gone. (The 33 was because I had the egr vacuum unplugged.)
What could I have done to cause the issue with the timing? What's with the 91 going away and coming back? What's with the 44 coming and then disappearing? I tested the o2 sensor I took out and it was performing fine. Is the EEC going haywire? Is there any way to rest the EEC?
Have you tested the wiring on the O2 sensor? Did you try wiggling the wiring while going the test? what sort of resistance reading di you get?
The timing is supposed to be supposed to with the SPOUT out.
Putting the distributor back in and setting the timing.
Revised 28-Jul-2013 to include warning about putting spark plug leads in a different location to attempt a to fix a distributor incorrectly installed.
You can forget about anything beyond this point if you don't have access to a timing light. You will never get the timing set right without one.
Putting the distributor back in is fairly simple. Pull #1 sparkplug, put your finger in the sparkplug hole, crank the engine until you feel compression. Then line up the TDC mark on the balancer with the pointer on the engine block.
The distributor starts out with the #1 plug wire lined up at about 12:00 with you facing it. Align the rotor to about 11:00, since it will turn clockwise as it slides into place.
Align the distributor rotor up with the #1 position marked on the cap, slide the distributor down into the block, (you may have to wiggle the rotor slightly to get the gear to engage) and then note where the rotor is pointing.
If it still lines up with #1 position on the cap, install the clamp and bolt. If not, pull it out and turn 1 tooth forwards or backwards and try again. Put the #1 spark plug back in and tighten it down, put the clamp on the distributor, but don't tighten it too much, as you will have to move the distributor to set the timing. Note that there is no such thing as one tooth off on a 5.0 Mustang if you follow the spark plug wire order on the distributor cap. If it doesn't align perfectly with #1 position, you can turn the distributor until it does. The only problem is that if you are too far one way or the other, you can't turn the distributor enough to get the 10-14 degree optimum timing range. Don't move the wires from the positions shown on the cap on fuel injected engines!!!! The #1 position cast into the cap MUST have the spark plug wire for #1 cylinder in it. Do it differently and the timing for the fuel injectors will be off. The computer uses the PIP sensor to time injector operation by sensing the wide slot in the PIP sensor shutter wheel. If the injector timing of #1 and the firing of #1 do not occur at the right time, the injector timing for all other cylinders will be affected.
Setting the timing:
Paint the mark on the harmonic balancer with paint -choose 10 degrees BTC or 14 degrees BTC or something else if you have NO2 or other power adder. I try to paint TDC red, 10 degrees BTC white and 14 degrees BTC blue.
10 degrees BTC is towards the drivers side marks.
Note: setting the timing beyond the 10 degree mark will give you a little more low speed acceleration. BUT you will need to run 93 octane to avoid pinging and engine damage. Pinging is very hard to hear at full throttle, so it could be present and you would not hear it.
Simplified diagram of what it looks like. Not all the marks are shown for ease of viewing.
ATC ' ' ' ' ' ' ' ' ' '!' ' ' ' ' ' ' ' ' ' BTC
---------------- > Direction of Rotation as viewed standing in front of the engine.
The ' is 2 degrees.
The ! is TDC
The ' is 10 degrees BTC
Set the timing 5 marks BTC. Or if you prefer, 5 marks towards the driver's side to get 10 degrees.
To get 14 degrees, set it 7 marks BTC. Or if you prefer, 7 marks towards the driver's side to get 14 degrees.
The paint marks you make are your friends if you do it correctly. They are much easier to see that the marks machined into the harmonic balancer hub.
At this point hook up all the wires, get out the timing light. Connect timing light up to battery & #1 spark plug. Then start the engine.
Remove the SPOUT connector (do a search if you want a picture of the SPOUT connector) It is the 2 pin rectangular plug on the distributor wiring harness. Only the EFI Mustang engines have a SPOUT. If yours is not EFI, check for a SPOUT: if you don’t find one, skip any instructions regarding the SPOUT
Warning: there are only two places the SPOUT should be when you time the engine. The first place is in your pocket while you are setting the timing and the second is back in the harness when you finish. The little bugger is too easy to lose and too hard to find a replacement.
Start engine, loosen distributor hold down with a 1/2" universal socket. Shine the timing light on the marks and turn the distributor until the mark lines up with the edge of the timing pointer. Tighten down the distributor hold down bolt, Replace the SPOUT connector and you are done.
The HO firing order is 1-3-7-2-6-5-4-8.
Non HO firing order is 1-5-4-2-6-3-7-8
attachment.php
Yes, I tested both o2 sensors. There was no resistance between the EEC connector and the o2 connectors. Both sensors were tested and showed between 0.15 and 0.78 volts.
I appreciate all the help, really I do. But, did you read my posts? Refer to post #16 and #22. I never messed with the dizzy, the wires, or did anything else that would cause timing to be off. I didn't loosen the dizzy and mess with the timing until after it wouldn't start. I thought it wouldn't start because I thought it was flooded, but as soon as I advanced the timing (to 30* btdc SPOUT out) it would start. While it was running, and with the SPOUT still out, I tried to retard the timing to 12* btdc, but it would stall.
Everything was fine until I was diagnosing the balancer. Something happened while I was turning the engine over without the coil hooked up.
What are symptoms of a bad TFI module?
The TFI module mounted on the distributor is usually the culprit for a high speed miss on a warm engine. If the problem does not occur when the engine is cold, the TFI module is definitely suspect. You may need a special socket to remove the TFI module, but most auto parts stores will have one for $5-$7.
Thanks for the reply. I also posted this over on corral.net. Consistent with what was mentioned here about the timing being off (dizzy installed wrong) one of their members said that perhaps my timing chain jumped a tooth.
At first I thought that was rediculous. I mean, it's a low mile motor. But the more I got thinking about it the more it seemed to fit. I wanna say 'no', but these motors didn't come with a nylon cam gear, did they?
Another possibility is a bad dizzy gear. I'll turn the motor by hand so that #1 is tdc on the compression stoke, turn the dizzy back to about where it was originally, and see how far off the rotor is from the #1 terminal.
I'm planning on it being off. Then I'll pull the dizzy and check out the gear. Hopefully that's it, because if it's not, I'll have to take the timing cover off and inspect the timing gears and chain.
I spent 12 hours yesterday working on this. Before I got into the front of the motor I set the balancer to 0* (tdc) and moved the dizzy back to about where it was when the timing was 12*. The rotor was about half way between terminal #1 and terminal #3. With the dizzy advanced to where it would run (timing at 30*), the rotor was on terminal #3. So something caused the timing to physically/mechanically jump. But what?
The dizzy was removed, and looked great. The gears showed normal wear and the teeth were not damaged at all. I also took a look at the cam gear that drives the dizzy. It also showed normal wear with no damage to the teeth.
Next I pulled the timing cover to inspect the timing set. The chain looked great, an the gears looked great, too. My dumbass pulled the gears and chain off before I thought about lining up the dots, so I will never know how far (or even if) the chain was off (how many teeth it jumped). There were no signs anywhere of the chain jumping. Both sprockets looked good. Both had normal wear, and nothing was broken. The chain ha a tiny bit of slack, but not enough to cause any problems. Anyway, I lined everything up and reinstalled the timing set. When "dot to dot", and with the dizzy eyeballed to be where is use to be (12*) the rotor was a tad clockwise of terminal #1. It all looked how it was supposed to.
I put everything g back together bit haven't had a chance to start it yet. I'll keep you posted....
When I left the car, I left the dizzy at about TDC (middle of rotor pointed at middle of terminal #1). The next day, my dad change the oil because some bits of timing cover gasket and some coolant dropped into the oil pan. He was unable to start it. He had to rotate the dizzy all the way clockwise (until the TFI module hit the thermostat housing) before it would start. He didn't have a timing gun, but if it's the same as it was, it would be about 30* BTDC.
I am 100% sure the timing sprockets are dot to dot, and I am also 100% sure the dizzy is installed correctly. The timing chain doesn't have nearly enough slack to cause that much variation at the dissy. The cam looks good, and so does the dizzy gear. This is how it's supposed to be oriented (and how it was installed).
This is the only way it will start and stay running, with it at about 30* btdc
Obviously something is wrong. Something is causing the timing to I ordered a 1992 Powertrain Control Emissions Diagnosis manual (PCED), so hopefully that will help.
