I'm hoping some Stangneters are online and can help me with a couple of quick responses. I'm ready to fire my 347 for the first time, but I turn the key and nothing happens
I don't get a solenoid click or anything.
What I've done so far:
Thanks
- Had battery checked at Autozone and it is good and has a charge
- I jumped the solenoid from one post to the other and it cranked
- I am using the Crane Hi6 ignition system and matching electronig distributor- I rechecked all of the connections and all look fine. With the key in the on position, the red LED is lit, indicating the unit is functioning
- I am using a Powermaster starter #9603. This has a 1 wire hookup from the right side (opposite the battery + connection) of the solenoid straight the starter using heavy guage battery cable. There is a switch post on the starter also and the instructions stated to use a jump wire to the Batt post on the starter, which I did.
- I am using a Powermaster 1 wire alternator. I ran heavy cable to the Batt side of the solenoid. I still have the original voltage regulator harness plugged into the regulator, but have also tried unplugging with no different results. I don't this this has anything to do with my problem, but wanted to state this.
- I have checked my grounds. Battery is grounded to engine block with heavy guage battery cable and a ground strap runs from the firewall to a bolt on the engine.
Thanks
