  • SN95 4.6L Mustang Tech
Looking for Transmission Advice - 03' GT
  • Thread starter Thread starter abright52
  • Start date Start date Nov 16, 2007
abright52
DeKalb, IL
Nov 16, 2007
  • Nov 16, 2007
2003 Mustang GT 5spd with 60K miles on it. Initial problem was that it was stuck in fifth gear and would not move.
Trans was removed and taken to a shop and they gave a quote of $1700 to fix it....not including a clutch. I am not a Mustang guy, but it really seems high to me. They said that they would replace everything relating to 5th gear, all synchros, and all bearings.
I can get a factory rebuilt 3650 for $1199 from D&D Performance. That would be better than the $1700 option, but it is worth it for the same transmission? It has been taken to the track a few times and has done its share of burnouts. I doubt that any of that behavior will change, so I am looking for something that will last.
Would I have to convert it to a TKO 500 to get a stronger trans or are there other options?
Thanks in advance.
White Stang
467
Ft Lauderdale
Nov 17, 2007
  • Nov 17, 2007
If you want to stay manual I would get a TKO 600
2002BLGT
Well-Known Member
Dec 18, 2003
2,945
Bedford VA
Nov 18, 2007
  • Nov 18, 2007
Thanks in advance.
find another tranny shop , that is too high for a tranny rebuild job
abright52
DeKalb, IL
Nov 18, 2007
  • Nov 18, 2007
How strong are the auto trannys? How much work would a swap like that be?
Rusty67
20+ Year Stangneter
Dec 3, 2002
3,749
37
109
LA, CA
Nov 19, 2007
  • Nov 19, 2007
For the love of God, don't put an auto in ! Thats a waste !
How hard do you drive your car ? It sounds like you broke the shift fork or something and the hub for 5th gear wouldn't disengage.
Also, what kind of mods does your car have ? Is it stock ? You shouldn't be braking a 3650 with a stock motor or even up to about 350hp unless you are abusing it (or got a bad one).
twogts4us
4,188
12
79
Dunedin, FL
Nov 19, 2007
  • Nov 19, 2007
Agreed! What the heck is wrong with your transmission - I mean, what are they diagnosing it with - what's the problem?
Mustang5L5
Mod Dude
Feb 18, 2001
43,349
18,085
224
Massachusetts
Nov 19, 2007
  • Nov 19, 2007
$1700 to replace 5th gear? Wow that's a rip.
For that much, buy a TKO.
T
TonyG
200
Owings Mills, MD
Nov 19, 2007
  • Nov 19, 2007
I had my T-45 rebuilt for $1200 (not including clutch), and I thought that was way too expensive. $1700 is crazy.
twogts4us
4,188
12
79
Dunedin, FL
Nov 19, 2007
  • Nov 19, 2007
yeah, we paid about $900 for my wife's 01 trannie to be rebuilt and I thought that was waaay too much too.
How did they come to that figure? What's labor and what's parts?
I'd go to D&D or Astro and get a rebuilt - or, as others have said, step up to a TKO 600.
F
ForPointSex
395
Mercer, NJ
Nov 19, 2007
#10
  • Nov 19, 2007
  • #10
I bought a rebuilt 3650 for $1200 including shipping and core return (the rebuilt tranny was $995). If you order, it only takes 3-4 days to get it. The same company sells on ebay with user name: smartpartsauto
http://www.smartpartsauto.com/manual_transmissions_mustang_tr3650_4014.htm
If you have time, you can get a T-56 for $1195 from the same place and upgrade. There are some extra parts you need for the swap.
http://www.stangnet.com/pbullitt/tremect56/index.html
You can also get an upgraded TR-3650 for $1,650 from Pro M.
http://www.promotionpowertrain.com/1231590.html
T
TonyG
200
Owings Mills, MD
Nov 19, 2007
#11
  • Nov 19, 2007
  • #11
The shop removed the tranny and sent it to a builder.
According to the shop, the builder charged $800 for parts (rebuild kit) and labor.
Then the shop added on $400 for labor to remove and reinstall transmission. $1200 total
Since I have longtubes, I expected some added labor costs for removing the tranny. But after seeing all the scratches and dents all over them, I could tell that they weren't very careful and just yanked it out. My Jet hot coating is ruined.
A
armyguy125sig
10
Fort hood
Nov 20, 2007
#12
  • Nov 20, 2007
  • #12
that sucks. would have just upgraded to a TKO-600
Mike97gt
it doe snot
10,633
the people's republic of massachusetts
Nov 21, 2007
#13
  • Nov 21, 2007
  • #13
thats not out of line. 400 for labor to R+R is about 4-5 hours at most shops for a car with the stock manifolds thats about the right time.
with long tubes I would have not touched it for any less than 7 hours to pull the tranny and then the rebuild time is extra. They F-ed up on the quote and did not charge enough hours to do the job properly and loosen the header thats why your headers got damaged.. They should have called you and explained the situation and asked for extra time.
The way i handle modded cars is I explain why it's going to be extra and if they don't wan't to pay the extra then i don't work on it. This is the best way to handle it, hacking the car is not.
I know that might seem like a lot extra to pay but with long tubes it can take longer than that and we work flate rate so if I was doing the job I would only get paid the amount of hours the shop charged no matter how long I took to do it..
T
TonyG
200
Owings Mills, MD
Nov 21, 2007
#14
  • Nov 21, 2007
  • #14
svttech76 said:
...They F-ed up on the quote and did not charge enough hours to do the job properly and loosen the header thats why your headers got damaged...
I have a tubular k-member. Shouldn't that have made it easier for them to loosen the passenger side header?
Anyway, I agree with your latter point. I would have gladly paid extra labor to save my $350 Jet hot sterling coating. Its ruined now. Here are some photos:
http://forums.modulardepot.com/gene...ropping-t45-longtubes-much-damage-normal.html
white99gt
4,649
stockbridge,Ga(near atlanta)
Nov 21, 2007
#15
  • Nov 21, 2007
  • #15
Id convert to a tko (old school and can be had cheaper) or a tko 500 ..No need for a tko600 on a n/a car.Hell i ran a normal tko for years with no failures making 600+rwhp.
Once you conert to a tko setup the tranny work will be cake.Take tranny out,remove the bellhousing and a little twisting and it comes right out.No having to remove the headers esp longtubes(been there).
Rusty67
20+ Year Stangneter
Dec 3, 2002
3,749
37
109
LA, CA
Nov 21, 2007
#16
  • Nov 21, 2007
  • #16
Man, they effed your headers up perty bad. I would drive the car down there and ask them to put it on a lift. Then show it to them while its up there.
Speedometer Calibration
  • Sonny Bibb
  • Sep 11, 2026
  • Digital Self-tuning Forum
Digital Self-tuning Forum Sep 13, 2026
Sonny Bibb
W
Speedometer and shifting issues
  • wyatt-tetro891
  • Aug 17, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 18, 2026
wyatt-tetro891
W
97 GT with 03 explorer Eddie Bauer edition 4.6l
  • basbill73
  • May 10, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 11, 2026
squeak93
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
I
2000 GT Mustang - Transmission Cooler to Radiator o-rings
  • Iwarrior
  • Oct 4, 2025
1996 - 2004 SN95 Mustang -General/Talk- Oct 4, 2025
Iwarrior
I
