Looking in to getting some heads
Are the GT-40 heads nice or are the crap?
  • Nice
    Votes: 7 43.8%
  • Crap
    Votes: 9 56.3%
  • Total voters
Killercanary said:
If on a tight budget, the GT40P's are a decent performer, and if you look at Vib, green95droptop, etc they are making decent power and times with the GT40X's, but the regualr gt40 and aluminum GT40Y head are not worth the money IMHO. They are better than an E7 head, and can make decent power, but for the dollar, you're better off with a set of GT40P's or a used set of TW or edelbrock 6037's.
That's Green94droptop, Paul. HAHA, just busting on ya.
It's not all about the cylinder heads; I beleive cam selection plays just as big of a part in making power as does the heads. TFS claims you can use a pretty nicely sized cam with their 2.02" valves but they you always have to worry about piston to valve clearance. Let's face it, TW heads and an E cam won't produce the kind of power you should be making. You're are going to need a bigger cam with bigger valves. But then there's all sorts of driveability issues like bucking, etc., especially in a 5 speed car, ESPECIALLY in the SN cars. If I had to do it all over again, I'd probably go the Edelbrock route (60379's) or even the AFR165 route. It's not worth it now to gain just 10rwhp (under the curve); I couldn't justify spending another $600 and taking the car apart again. Only reason I went with the X heads is because of the price and the convenience factor. I knew who they had been owned by and I got 1.7 rockers, bolts, gaskets, and the heads for just under $1000. Only bad part is they are all hogged out (some might consider that good).
Anyhow, do it right the first time. If you have to spend the money to get a good set of heads, just do it. And it's not all about the hp numbers, knowing how to drag race helps too.
