Looking to update my suspension
02BlkStang
118
Austin, TX
Installing the springs this weekend, now I'm looking at some MM LCA's, and maybe some subframe connectors.
Anything else you'd suggest? Not looking to spend a whole lot, and this is my daily driver that see's a decent amount of racing.
+ 1 to what he said
Also, BIGGEST difference i made to my suspension was sway bars. The Anti-sway bars from Eibach are simply AMAZING. They cost about 250 bucks and are not that bad to put on. they will definitly make your car handle like something from Italy ha ha ha
if you want a street only machine, Steeda is pretty good. If you are more serious, Maximum, is a good choice. I have D&D Motorsports on my car with a coilover but there are several other good ones also. Just try and stay with one company for everything though.
san man is correct. MM does recommend this route, and probably is the best method.... however a lot of people find this very unappealing (our issue not MMs, every owner is impatient). I went springs/bilsteins first noticed a bit of a difference, then swaybars, noticed a large difference (i know they are to be used to fine tune the car, but i dont think i will ever get that far down the chain that i will neeed to fine tune anything)
my personal thoughts (by no technical basis at all) is to get springs/dampers, SFCs, LCAs, panhard and swabars then call it a day (this would do for a lot of people). I personally will be getting the panhard, LCAs and torque arm next, and then move to front Coilovers and then k member/a arms.... i just love handeling too much to stop.... and at this point i will probably have to remove the steeda swaybars and get something that fits to the final setup.... but alas, my screwup. its only money.
Torinalth
