loose rear end when shifting
tdubya
Anyone have problems with the rear end being squirrely when shifting? Started having a problem today with this. Even when shifting smooth, the back end does a little fishtail. It's bad enough to make me park it. Tire pressure good, no issues noted with tires on visual inspection. Does it both on up and downshifting.
yes i have the same problem, im not sure what is causing it yet, i have a broken motor mount and i believe the engine is twisting and changing the pinion angle for the drive shaft. if you have a broken mount let me know
