  • 1994 - 1995 Specific Tech
losing a/c freon
  • Thread starter Thread starter amplifier28
  • Start date Start date Jul 19, 2008
amplifier28
222
  • Jul 19, 2008
i lose my freon but can not find leak. is it possible to have leak on evaporator/heater core?
FlyBy763
439
Palm Bay, FL
Jul 19, 2008
  • Jul 19, 2008
Evaporator, yes. Heater core, no. Buy some freon with the UV leak detector in it and see if you can find the leak then. Maybe try some with stop leak in it too. Is it a fast leak or slow leak?
amplifier28
222
  • Jul 19, 2008
the freon lasted for around two months the first time i filled it with one can of freon and one can of stop leak when i bought the car. the freon lasted about a month the second time i filled it with one can of freon with stop leak. i have recently put two cans of freon with stop leak. where is the evaporator located. i know that the heater core is located behind the dash. is the evaporator there too? i looked in latemodel restoration supply and they do not carry one for a 94-95 stang. where will i be able to buy a good quality evaporator?
FlyBy763
439
Palm Bay, FL
Jul 19, 2008
  • Jul 19, 2008
They are actually in the same unit behind the dash. Perhaps I misspoke. Not sure if freon ever actually goes through the evaporator...
amplifier28
222
  • Jul 20, 2008
i will try the UV leak detector first today and see if i can see the leak. by the way, how many of the small freon cans does the a/c system require if it is empty?
KasperG
38
  • Jul 20, 2008
In the past I have found out that if you, or the previous owner changed out the compressor or any other part of the a/c system and reused the original o rings. Or, even used new ones from the parts store, a leak can develop. The parts store o rings are crap in my opinion. I have seen it first hand where a store bought o ring would hold under vacuum, then freon was added and it leaked out slowly over a week. I have since then insisted on only using dealer o rings. So just keep that in mind before you go replacing any other expensive parts. Simple and cheap first... p.s. also check the fittings where you add freon. There is a valve in there like in a tire. Replace it. It is a common place to leak.
amplifier28
222
  • Jul 21, 2008
well, the original owner had replaced all the a/c system components before. i will keep in mind the o-rings and valves when i use the UV leak detector. thanks.
2010 GT AC issue
  • 2010torchredgt
  • Jun 28, 2026
  • 2010 - 2014 Specific Tech
2010 - 2014 Specific Tech Jun 29, 2026
2010torchredgt
A/C Issues
  • Boats90GT
  • Jun 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 11, 2026
Mcmahst
K
86 GT Water Pump
  • Kade5114
  • May 11, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 11, 2026
nickyb
2001 v6 New compressor issue
  • badmech
  • Apr 30, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Apr 30, 2026
badmech
J
Mustang 1968 coupé restoration hvac
  • JackStang68
  • Mar 3, 2026
1965 - 1973 Classic Mustangs -General/Talk- Mar 27, 2026
zookeeper
