  • SN95 4.6L Mustang Tech
Losing Refrigerant rapidly on my 98 Mustang GT
  • Thread starter Thread starter TekoSn95
  • Start date Start date Jun 21, 2025
T
TekoSn95
Palm Desert California
Jun 21, 2025
  • Jun 21, 2025
Hey guys hopefully I'm not posting this in the wrong forum section but hopefully I am
I recently just installed a new AC compressor into my 98 Mustang GT made sure everything was plugged in and the line connections at the compressor we tightened up though now I do run into an issue. I am rapidly losing refrigerant. I took the car to AutoZone just yesterday bought a small can of refrigerant and the AC started to get cold but when I stopped somewhere else for about 11 or so minutes and came back to the car my AC was running warm again and the compressor was short cycling. So what could be my issue? I do notice some green dye around the low side Schrader valve so that could be my issue but I do want to ask here as well should I re check the lines that connect to my AC compressor? I can add pictures if needed
Mustang5L5
Mod Dude
Feb 18, 2001
43,330
18,058
224
Massachusetts
Jun 24, 2025
  • Jun 24, 2025
Sounds like you have a leak, which needs to be repaired. I would look around elsewhere for signs of leaking dye.
If you pull a vacuum on the system? Does it hold that vac for an hour or two?
T
TekoSn95
Jun 24, 2025
  • Jun 24, 2025
Hey Mike.
When I did first run a vacuum on the system to remove moisture it held that vac for an hour or two but throughout the day I had to keep removing and putting on the guage system from the low side and high side AC ports. Though I believe at one point I mightve put too much pressure down on the low side pipe possibly cracking it at the valve stems base because there's a tiny bit of liquid pooled up at the base of the low side valve stem. I did look in other areas but there wasnt any signs of leaks as far as I saw (My AC Compressor did come with new seals for the compressor to line connection). So for right now I just bought another low side pipe assembly and im planning on replacing the pipe today and when its finally done getting installed im gonna run another vacuum
nickyb
I gotta say i never painted my nuts, Never Ever
3,022
1,656
163
nevada
Jun 24, 2025
  • Jun 24, 2025
How did you pull too much vaccum? If your gauges read 28-30 inches and hold it when you shut the pump then your golden.
T
TekoSn95
Jun 24, 2025
  • Jun 24, 2025
I should've explained when I put the gauge connection on the low side pipe it was hard to get the connection on so I put physical pressure on the pipe to get the connection on. the gauges read at 28-30 inches when I pulled a vacuum and it did hold when I shut the pump off but when I finished running a vacuum. I had a can of refrigerant that I thought I could throw into the system (it wasnt that much refrigerant but enough to let the compressor clutch kick on). I then went out to AutoZone got a bigger can and I guess when I put pressure on the low pressure side connection again I mightve cracked the pipe at the base of that connection (if this doesnt make sense I can attach a photo of what I mean).
Mustang5L5
Mod Dude
Feb 18, 2001
43,330
18,058
224
Massachusetts
Jun 24, 2025
  • Jun 24, 2025
Sounds to me like you might be right with the crack on the low side line, but I can't see it for myself.
When you go to pull vac, best to let it run overnight you can. If not, the longer, the better. Really these systems need to pull down to 500-1000 microns, which is 29.88 inHg. 29.00inHG is about 23000 microns, which is ok, but not really ideal for AC work. Most gauges on the manifolds don't have that sort of resulution....so the more time you can vacuum, the better.
T
TekoSn95
Jun 24, 2025
  • Jun 24, 2025
Yeah ill do that!
Just got the new line in so im ready to put it in the car and hopefully have cold AC again!
nickyb
3,022
1,656
163
nevada
Jun 24, 2025
  • Jun 24, 2025
Good luck,and let us know.
T
TekoSn95
Aug 17, 2025
  • Aug 17, 2025
Well I shouldve made this post earlier but thankfully a friend of mine caught it before I did anything else he has a 97 GT and he recently replaced his valve stems on his hoses and he told me despite it looking like the valve stem is apart of the line it does come off and can be replaced for cheap. So I did have a leak from my low side but just around the valve stem which saved me a ton of money and time. Car runs cool again and im proud of it though there are other issues I need to work out with it but right now im happy with it
Reactions: gkomo and Noobz347
A
Strange AC issue
  • Adanesahde
  • May 3, 2025
SN95 4.6L Mustang Tech May 3, 2025
Mcmahst
G
2005 Mustang GT AC cycling on and off every minute
  • GeorgeSwadling
  • Jul 12, 2025
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Jul 12, 2025
GeorgeSwadling
G
C
98 gt fuel pressure issues
  • chasecollier1984
  • Jun 2, 2026
SN95 4.6L Mustang Tech Jun 2, 2026
chasecollier1984
C
I
98 Mustang GT dying
  • ItsMason
  • May 14, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jun 25, 2026
lenzgt
L
F
AC Compressor Power & Contour Fans
  • Fri Guy
  • Aug 27, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 15, 2026
BoostedRed89gt
