lost fuse panel cover
Hey thanks a bunch, what my prob is my turn signals just quit replaced flashers on direction and emergency.I also replaced coloumn switch all fuses check good any ideas.
Check for any loose wires/connections on the actual hazard lights switch. You gotta remove it from the dash though. My connector was all f'ed up and that was causing my flash lights not to work. Go figure. :shrug:
i was wondering what came of this? i am having the same problem, flashers work fine, turn signals dont work at all, replaced the flasher still nothing...:shrug:
The flasher is not mounted on the front of the fuse panel. The flasher on the front of the fuse panel is a separate one for the hazard lights. It is in one of several places, depending on when your car was made. Some are behind the fuse panel on the back side, others are behind the radio and some are behind the glove box.
Other possible problem sources for the turn signal malfunction are the ignition switch, multifunction switch and the plastic shell that holds the turn signal wiring connector pins.
A word of caution about multifunction switches is in order here. The multifunction switch (high/low beam, wiper, turn signals) are different for different years. 87-98 will work in any 87-89 car. The 90-93 switches only work in 90-93 cars. You can't put an early model switch in a late model car, nor can you put a late model switch in an early car.
Supposedly you can move the pins around to make the switches work in model years that are different from the car the switch came out of. I cannot verify that and haven’t tried it .
The following diagram is for 87-89 model cars.
Turn signal switch wiring:
attachment.php
yeah i found the flasher for my turn signals, mine was behind theconsole by the radio on the pass side...
thanks for the heads up on the switches, i was just on my way out to get a switch. :nice:
