  • 1994 - 1995 Specific Tech
lost my wheel lock key.....HELP
  • Thread starter Thread starter nmcgrawj
  • Start date Start date Apr 3, 2007
nmcgrawj
Advanced Member
Sep 28, 2003
3,651
Indianapolis, IN
Apr 3, 2007
  • Apr 3, 2007
Whats up everyone, been a long time. Tryin to get things together with my motor. Someone broke into my car while it was sitting and stole my speakers, but now that im looking for things i need, i cant find my wheel lock key nor tools that i could have sworn i still had in there. Maybe i have misplaced them but i dont have time to pray for them to pop up. How the hell do you get wheel locks off? I have the kind that are circular on the outside with the pattern cut into the middle of them. I also have lug nuts that are the bullet style with the pattern on the outside but im pretty sure those will be fairly easy to hammer on a socket to get em off.
Please help!:SNSign:
gunmetal5.0
144
Chico, CA
Apr 3, 2007
  • Apr 3, 2007
Grimper. There is a type of tool that i've seen on TV, it's a socket wrench that has a hollow center with some sort of spring loaded rods filling it. It's designed to fit over any size nut/bolthead. It conforms over it by having the spring loaded rods that are over the surface go inward while the ones around the edge of the nut stay down. Hard to explain but i've thought that something like that could be used for your application. Does this make sense?
gunmetal5.0
144
Chico, CA
Apr 3, 2007
  • Apr 3, 2007
Called a gator grip apparently. Check it out. http://images.amazon.com/images/P/B000065CJ8.01.MZZZZZZZ.jpg
94-302-vert
1,947
NE CT
Apr 3, 2007
  • Apr 3, 2007
Find a socket that BARELY fits over it, cut a piece of metal, something thin, to use as a shim, hammer this combination onto the offending lug and turn away. The key is to have the wege be VERY tight. since it is a single point of contact it is easier to hammer on. I couldn'g get the tight sicket hammered onto mine and I was only able to vice grip 2 of the 4. the other 2 came off sooo easy....
'94ChickStang
301
northern ca
Apr 3, 2007
  • Apr 3, 2007
If you have a shop that you've bought tires from locally they'll usually do small stuff like this for free...Just have them crack those suckers off of there, bring them new ones from any parts store to put back on
Adam95GT
2,564
Burlington, NJ
Apr 3, 2007
  • Apr 3, 2007
Get a socket slightly bigger... then make a loop out of sand paper and wrap it around the lug... hammer on the socket... then turn
STM1965
185
Ontario
Apr 3, 2007
  • Apr 3, 2007
I just had mine removed a few weeks back, took it to the dealer, $20 bucks later all four off, and they didn't even have the key. Our 95's use McGuard, or least thats what was on mine. Couldn't even buy just off the shelf lug nuts due to the amount of taper thats on the shoulder
skylovia
66
  • Apr 3, 2007
like this guy said, ANY tire shop can do this for you, and dont pay more than 20 bucks to get it done or your getting ripped off!
R
RAD
167
  • Apr 3, 2007
http://cgi.ebay.com/ebaymotors/SK-9...-Kit-2-pc_W0QQitemZ120102599133QQcmdZViewItem
I have exactly same kit and it does wonders , tried to find better link but can't find it , I paid like 50 - 60 bucks for it
gunmetal5.0
144
Chico, CA
Apr 3, 2007
#10
  • Apr 3, 2007
  • #10
Or you can get the gator grip for 12 dollars and have it for future use. But hey that'd be too easy.
urban96
bubb rubb says:"woo woooooo"
3,464
Syracuse, NY
Apr 3, 2007
#11
  • Apr 3, 2007
  • #11
i took mine to sears and them take mine off, it was around 20
vp6799
124
Massachusetts
Apr 4, 2007
#12
  • Apr 4, 2007
  • #12
Had to do this to mine as well. The gator grip is too small to fit around the lug, I tried it. Ended up going to the local tire shop and getting an old mcgaurd lock that they didn't know what was for. Hammered it on and they came right off. Tried the socket deal but it just spun on the lug. Using another key gives you the new groves that you make when it gets hammered on for grip.
Black94Cobra
81
KC MO
Apr 8, 2007
#13
  • Apr 8, 2007
  • #13
I lost mine too. It was a huge pain. I went to parts store ane got some extractors. They look like the ebay link. It is still a tough job at home because the locking lugs are hardened and completely round. You cant hammer on a socket, trust me they will break.
KamiKaziDK
555
Mesa, Az
Apr 8, 2007
#14
  • Apr 8, 2007
  • #14
Is your car running? Drive down to discount or one of the other big tire/wheel places....custom wheels places too. if they sell the lugs....they usually have the key to go with them. I bought my lug key for like 8 bucks when I lost my old one
final5-0
Mustang Master
Apr 6, 2003
6,817
12
79
DFW Texas
Apr 8, 2007
#15
  • Apr 8, 2007
  • #15
Hammering on a socket works just dandy
The thing is ... You need to hammer on an "IMPACT" socket
Regular chrome sockets won't take the abuse of using this method of
wheel lock removal and as said above ... they usually will just split when
you try to hammer them on good and tight
Grady
01 GT DRIVERS SIDE DOOR LOCK CYLINDER LINKAGE
  • Scwhitten
  • May 13, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Jun 19, 2026
melo.timo
M
L
2000 Mustang PATS - Broken Key and Wire - HELP!
  • Laree Taylor
  • May 7, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 12, 2026
manicmechanic007
  • 2000xp8
  • Jul 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 18, 2026
AeroCoupe
M
Too much for me to repair in my current housing situation
  • My Drama Magnet 04 Gt
  • Apr 1, 2026
  • The Welcome Wagon
The Welcome Wagon Apr 14, 2026
  • AeroCoupe
  • Aug 2, 2026
AeroCoupe
