Here is what i got on the motor
306
SRP pistons with stock rods and crank
1.6 RR
Strike force alum heads 2.05/1.6 valves Crane springs
F-Cam
30# inj with C&L Mass
Trick flow street intake
MSD &coil
Well after having to take my water pump off 4 times and change all gaskets, grind down the end of my distributor 1/8", Bypass my MSD cuz it decided not to work....Finally the car started today. BUT ran like crap... At first we had a hard time finding timing.. finally got it close.. Then we decided to take it down the street...The idle kept staying up when i would shift, then i lost my brakes... So my buddy who is a mechanic started spraying around the intake manifold gaskets ..carb cleaner.. and when he would do it the idle would change ... So i think this is what i deserve for using cheap intake manifold gaskets. Would that leaking have a great affect on the idle? We are doing a vaccum test tommarow but im sure that they have to be bad... Any opinons on the MSD? Its a 6-AL and it use to work.. We have power goin to it, Just no spark from it.. I never touched any wires when i changed the motor. Problems gotta love em...
THANKS CRAIG
306
1.6 RR
F-Cam
MSD &coil
THANKS CRAIG
