I just turned my key on and heard a loud pop from under the hood. The car didn't want to start at first and took about 6 or 7 rolls more than normal to fire, then it was idling at 1300-1400 rpm instead of the normal 900-1000. I was able to move it into the garage without touching the throttle.
I just got home from a short cruise and shut the car off while I moved my bike out of the garage. This happened when I went to start it back up a few minutes later.
I had just changed the IAC response time from 303ms to 250ms in the computer. That's the only thing I changed other than the tip in/throttle accel pump settings. Did I blow up the IAC??? TPS is working like normal, and the MAP sensor looked right so I don't think it's a vacuum leak...
Swapped IAC's, same problem. Unplugged the IAC, idles fine at 850-900. I did have the IAC set at 50% for an idle of 950ish, but now I have to set it down to about 15% for it to idle below 1000..... And with it set that way, after fixing my timing which somehow was a couple degrees advanced, it idles perfectly at 950 with no surging or hunting which is new...
