  • SN95 4.6L Mustang Tech
Low 11s High 10s?
  • Thread starter Thread starter funcrusher
  • Start date Start date May 25, 2004
F
funcrusher
27
Virginia
May 25, 2004
  • May 25, 2004
I just got all the suff done in my signature and the car needs to be tuned so I don't know any numbers yet. How much hp do you all think I will be making when I get it back and what do you think she will be able to crack into 10s?
Coming up in August: VT Engines 302 Racing Shortblock
I only get these goodies cause I am sponsored
Monkie
1,678
Under the arch
May 25, 2004
  • May 25, 2004
no
R
rob1
94
Indiana
May 25, 2004
  • May 25, 2004
probably not.
GoBabyVroommm
1,156
Chicago, For Realss???!!!
May 25, 2004
  • May 25, 2004
Nuhh but i'll tell you this you'll blow your motor soon after the tune. If its a stock short blow its done. Not a bad set up just should have done everything at once.
BVille99GT
283
Brownsville TX.
May 25, 2004
  • May 25, 2004
No, but what is your race weight?
M
mwdguy
I gave my car a rim job!
504
Edmonton, AB Canada
May 25, 2004
  • May 25, 2004
Nope ..
T
tangerine
555
millen, ga
May 25, 2004
  • May 25, 2004
If you leave out the hole at about 6 grand and have a set of wrinkle wall slicks with the new motor and you might want to invest in a new trans while you are at it if you have the stock t-45. and you might also want to consider a build rearend with 31 spline axles. yeah then it may be possible but not on just 8 psi.
F
funcrusher
27
Virginia
May 25, 2004
  • May 25, 2004
after the short block it's getting 33 spline race axles and spool T-56 and I am uping it to 17psi Everything should be done by October. wont be getting slicks ever though, I want to race DR class. Yeah I know it is gonna blow the bottom end if I push it too hard but my mechanic said he could tune it down and that I would probably be ok and if the engine does blow I dont care it isn't my daily driver and I am getting ready to get the short block
  • Gulftown980x
  • Jul 29, 2026
squeak93
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
D
Will 2023 (Non-Handling Pack) Mach 1 Wheels Fit A 2013 Mustang GT OK?
  • dmw_4814
  • Oct 27, 2026
  • 2010 - 2014 Specific Tech
2010 - 2014 Specific Tech Oct 27, 2026
dmw_4814
D
SN95 Desktop 363 Engine Combination - Looking for input
  • WhiteCobra95
  • Sep 8, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 6, 2025
Habu135
Need some camshaft guru advice on power loss from supercharger to nitrous
  • TTSaleen
  • Dec 1, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Dec 29, 2025
revhead347
