The low beams (both sides) on my 2000 GT stopped working. Parking lights and high beams both work. The bulbs appear to be fine. I am diagnosing per the service manual. Both low beam fuses in the Central Junction Box (in the car) are fine. I have ~12V at these fuse locations. I checked for voltage at the bulb connectors, and I have no voltage. According to the wiring diagram, the low beam wires go from the Central Junction Box through the C105 connector to the bulb connector. My assumption is that the problem is at the C105 connector, but I really do not know what the problem could be. This connector is visible and difficult to access from the inside of the car. It is not visible on the other side of the firewall in the engine bay.
Any suggestions? Do I try to inspect that C105 connector? Can the light bulb connectors fail? Can there be a grounding issue? Anything else I can check?
I have searched the forum and have not found any solutions.
Thanks.
Thanks.
Thanks for all your advice burns.
