Low Down Dirty Codes
  • Thread starter Thread starter sands9330014
  • Start date Start date Jan 6, 2025
sands9330014
69
japan
Jan 6, 2025
  • Jan 6, 2025
When my Mustang warms up, it emits black smoke and the engine starts idling. 12, 18, 26, 42, and 92 were detected. I replaced most of the sensors, but it still doesn't work. Please help.
General karthief
20+ Year Stangneter
Aug 25, 2016
27,955
10,598
203
polk county florida
Jan 7, 2025
  • Jan 7, 2025
This is an old thread.
You need to start a new one with more car info like, how long you've had it, recent tuneup, modifications that kind of thing.
Admin Dude
Jan 4, 1985
43,174
21,343
234
Box behind Walmart
Jan 7, 2025
  • Jan 7, 2025
Let's start here.
OP, what's your year and mods?
I assume those are the codes you have pulled?
What other symptoms/issues are you having?
Mustang5L5
Mod Dude
Feb 18, 2001
43,265
17,952
224
Massachusetts
Jan 7, 2025
  • Jan 7, 2025
Code 12: System cannot raise engine speed above normal idle. This means the ECU was unable to raise the idle 1500 RPM during the self test. The IAC could be faulty, disconnected or maxed out.
Code 18: See Here
Code 26: MAF out of range
Code 42 & 92 : system rich.
Code 42 passenger side sensor, as viewed from the driver's seat
Code 92 is the driver side sensor, as viewed from the driver's seat.
The rich condition may be a result of the other codes. I'd probably take a look at code 12 first and then probably focus on 18 and 26
  • Gulftown980x
  • Jul 29, 2026
  • SN95 4.6L Mustang Tech
squeak93
Running very very rich
  • 2esoteric
  • Oct 31, 2025
Fox 5.0 Mustang Tech Oct 31, 2025
Fox '87 GT can't get to stay running
  • spilly
  • Mar 29, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 20, 2026
spilly
Help with window and possible engine
  • StefRena22
  • Jun 12, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 21, 2025
Willybill32
P
High idle issue and leaking after running.
  • PHoffman
  • Dec 24, 2024
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Dec 24, 2024
General karthief
