  • 1994 - 1995 Specific Tech
Low mount alternator kit?
  • Thread starter Thread starter ironindian
  • Start date Start date Jan 13, 2008
I
ironindian
  • Jan 13, 2008
Dose anyone know if anybody makes a low mount alternator kit for a 94 5.0? And how big of 15" drag wheel and tire can I get under it? And at what back spacing. I'm new to mustangs. Thanks alot.
Pokageek
2,767
MA, USA
Jan 13, 2008
  • Jan 13, 2008
Subscribing!
vladasap
294
nyc, ny
Jan 14, 2008
  • Jan 14, 2008
I
ironindian
  • Jan 14, 2008
I guess i'll make one my self.
earleys94gt
1,223
Ashley, Ohio
Jan 14, 2008
  • Jan 14, 2008
By low mount alternator kit, do you mean locating the alternator down further on the front of the engine? Like where/by the smog pump is?
Is this is what you mean, I know some supercharger kits relocate the alternator down there. Maybe you can find one of those brackets somewhere???
Otherwise you will probably have to make your own...
I
ironindian
  • Jan 15, 2008
Yea,that is what in mean,i'm not running a.c. or power steering I might even run a elec. water pump ,I think lowering the alt. will clean up the look under the hood.
And thanks for the idea.
Redsnk95
2,243
Houston, TX
Jan 16, 2008
  • Jan 16, 2008
I run the Moroso alternator kit, it has the alternator down a little lower. I just run a crank pulley and electric water pump and nothing else. As for the wheel without any cutting/modifying a 15x11 is about the biggest you can go. I run a 28x10.5 tire and 15x10 (w/ 6" backspacing) with no modifications.
I
ironindian
  • Jan 16, 2008
Thanks Redsnk95,will a 10x15 with a 6.5 b.s. work? And your car is exactly what I'm trying to do.A 10.66,347 NA is great! My last car was a 434 ci.race gas,small block chevy and only ran a 10.26@130 NA. at 3000 lbs. Would mind sharing your combo,or can I contact you and ask you some questions,i've had alot of cars but this is my first ford build up.
Redsnk95
2,243
Houston, TX
Jan 16, 2008
  • Jan 16, 2008
The 6.5 might work...you will need to do some work on the back side of the inner fender since you are pulling the wheel in so much..but nothing a BFH can't fix.
My combo is pretty simple:
347 11:1/AFR 205s/AFM cam/TFS Box intake/C4/good converter/3200lbs/pump gas. Everything is out of the box. If you have specific questions feel free to shoot me a PM or ask here nothing to hide on my combo.
Here are a few pics of the alternator bracket....very simple to use costs about $80 from Jegs. I use a 27.5" belt. Please excuse the belt dust. Only advice I can give is do not use the POS bolt they give you...it broke on me and caused a bunch of belt slippage. I went to the hardware store and pickedup a nice thick Grade 8 bolt and it works perfect.
http://www.mustangmods.com/ims/u/611/6063/202423.jpg
http://www.mustangmods.com/ims/u/611/6063/202424.jpg
http://www.mustangmods.com/ims/u/611/6063/202425.jpg
Pokageek
2,767
MA, USA
Jan 17, 2008
#10
  • Jan 17, 2008
  • #10
Prettycool. Thanks RedSnk95! Great thread.
I
ironindian
#11
  • Jan 17, 2008
  • #11
Thank you redsnk95
vladasap
294
nyc, ny
Jan 18, 2008
#12
  • Jan 18, 2008
  • #12
so this moroso bracket was a direct bolt-on???!!!
if so pleaseeee give me a lil more detail of which one it is or a part number would be great
THANKS !!!
ford302redneck
85
Hartsville, SC
Jan 18, 2008
#13
  • Jan 18, 2008
  • #13
How much hp does that combo make?
Redsnk95
2,243
Houston, TX
Jan 20, 2008
#14
  • Jan 20, 2008
  • #14
Just search on Jegs or Summit look for the SBF alternator bracket by Moroso, its like $90 or so.
Ford302Redneck: I have no clue how much power the motor makes it has never been on an engine dyno nor has the car been on a chassis dyno. You can do the math 126 mph @ 3200lbs to get a rough guesstimate.
I
ironindian
#15
  • Jan 21, 2008
  • #15
Het Redsnk95 what kind of wheels are you running? I'm having a hard time finding a 15x10 with a 6.0 backspace.
Redsnk95
2,243
Houston, TX
Jan 21, 2008
#16
  • Jan 21, 2008
  • #16
Bogart Racing Wheels. They will make anything you need.
Killercanary
The car that set the bar.
Altoona, PA
Jan 21, 2008
#17
  • Jan 21, 2008
  • #17
Troy, didn't you have a rousch racing bracket at one time? I too have been looking for a solution to run the alt. as a tensioner and to delete the stock alt/smog bracket. Was this kit made for our cars?
Edit: Is this it?
Alt. Bracket
Redsnk95
2,243
Houston, TX
Jan 22, 2008
#18
  • Jan 22, 2008
  • #18
That's the one. It is not 94/95 specific but it works perfectly. I searched and searched for a 94/95 specific setup but as always we are the red-headed step child for special parts. I went through 4 setups (including the Roush bracket) till I was able to get the Moroso to work and it works just fine.
Paul, also hope to have some new numbers for ya in about a month. Got my converter reworked (hopefully we didn't go too crazy with it...lol) and a new cam from AFM, the new setup should see 6k rpms off the line, 7300 shift point and since I am dropping down to a 26" tire (from the 28") we're gonna zing the motor to about 7600 out the back end...lol...hopefully she holds. I don't think she'll mph much more than she does now...probably 127-128 but the front half of the track should be a huge improvement. And then I should get the new meter from AFM by March to test out.
  • 2000xp8
  • Jul 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 18, 2026
AeroCoupe
P
Electrical 2001 GT Overcharging
  • PseudoGT
  • Dec 3, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Dec 13, 2025
A
Resolved Electrical Help Please
  • Alabama
  • Jan 22, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 22, 2026
AeroCoupe
  • AeroCoupe
  • Aug 2, 2026
AeroCoupe
E
2007 GT Stalls when lights or a/c turned on
  • ejscarfo
  • Jun 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Sep 26, 2026
manicmechanic007
