Low Power to the Pump
  • Thread starter Thread starter sliepnir16
  • Start date Start date Jun 9, 2006
sliepnir16
26
  • Jun 9, 2006
I have been getting codes 87 and 96. I just started trouble shooting by checking the power wire to the inertia switch. The most voltage coming from it is about 11.42DC. I then unhooked the harness to the fuel pump by the tank under the car, turned the key on and checked its power wire. I can't remember the exact voltage but it was only 6.??DC therefore I knew it was too low. Id say after I drive around for a while and these wires get heated up it causes my problems. The relay is getting over 12VDC. Could it possibly be a bad ground or is it a wiring problem. Id appreciate any help.
Bolt on 5.0
302
Suffolk, NY
Jun 9, 2006
  • Jun 9, 2006
check resistance pin to pin and you should prob get a reading of about .3 - .5 ohms.
M
Marlboro_Man
437
Houston, TX
Jun 9, 2006
  • Jun 9, 2006
You will only get 12v at the pump when it is priming, after that 6-7 volts is all you will get untill the car is running.
11.42v is within spec. Chilton says within 0.5v from battery voltage (12v).
I just dealt with all this fuel pump **** last night on my friends car lol.
sliepnir16
26
  • Jun 9, 2006
I just noticed that when It starts running like crap I get a different noise from my pump. Instead of coming on and priming smoothly like it should, it comes on more like a grunting noise like its mad or something. Is that another indication of a bad fuel pump?
HISSIN50
34
129
Jun 9, 2006
  • Jun 9, 2006
You can jump the negative side of the relay coil to ground to keep the pump on for doing diagnostics. Otherwise it's a real PITA to keep cycling the key.
Good luck.
sliepnir16
26
  • Jun 9, 2006
Good luck.
What should I expect when doing this? The sound of the pump cutting out?
HISSIN50
34
129
Jun 9, 2006
  • Jun 9, 2006
You dont provide enough info about what you've tested and how to say more. Unless you can run really fast, it's hard to check the voltage at the fuel pump after you turn the key to on (before the pump primes out). That's where jumping the neg coil terminal to keep the relay energized can be helpful.
When I have a Fuel issue, I check each terminal on the FP relay socket.
See Jrichker's standard 'Cranks but wont start checklist' (he has to post it quite often) for info on testing the electrical side of the fuel circuit.
Good luck.
sliepnir16
26
  • Jun 9, 2006
I understood what you meant now,as Marlboro said that all that was within spec so now I don't see a problem there. Ive only tested the harness to the inertia switch and the main harness in the rear that provides the power to the pump, and also the relay. It seems like their is an exact time limit after i have cold started the car until it starts studdering on me. I have made a routine trip 17 miles away twice now and it started stuttering on me at the exact same spot on the road. If I am at a spot where I cant raise the rpms,eventually it will give out on me and not start for several minutes.I have replaced the TFI, Fuel pump relay, Fuel pressure regulator, and checked for arcing and all the basic stuff. I just ordered an under the hood fuel pressure guage from 50restoration so hopefully this will clear up my fuel pump concerns as it acts like a lack of fuel or acts like its vapor locking.
Thanks for the info, Ill see the checklist again, never been through the whole thing yet.
HISSIN50
34
129
Jun 9, 2006
  • Jun 9, 2006
Pulling codes again and installing your gauge (good call) sound like a plan.
Otherwise, when it dies out on you, check for spark real quick to make sure it's not an ignition issue.
Good luck.
M
Marlboro_Man
437
Houston, TX
Jun 10, 2006
#10
  • Jun 10, 2006
  • #10
The way you describe it , it does seem like a tfi problem but if you've replaced it i would think it's ok.
You can get a new pump from autozone for about $75 or order a 255lph pump for around $150ish and then at least you will know if it doesn't solve your problem that you have a new pump .
Have you changed the fuel filter recently? Pulled the codes?
sliepnir16
26
#11
  • Jun 10, 2006
  • #11
I have changed the filter. I put it in during the winter,the old one was swamped. Ive also checked the new one by unhooking the filtered side and draining the fuel into a bottle and it was clean as could be. Ive pulled codes so many times. I get the code 96 reoccurring no matter how many times I clear the codes, it may go away then I take it for a drive and it will show up in memory when koeo is pulled. The 87 I think is a new one so far, I may have gotten it before, but I dont think so. I notice in my trunk to the left of the inertia switch their are two more harnesses, at which the monitor circuit should be between the Inertia and the pump. Is the monitor supposed to be in the trunk? The only other code I get is the 02 sensor on the right side, but I dont think I will worry about that one right now since it seems like my whole motor is shutting down and not just one side/or cylinder. I appreciate the replies.
Electrical Ron Francis Headlight / Alternator Harness
  • dan50
  • Apr 30, 2026
Fox 5.0 Mustang Tech Apr 30, 2026
dan50
U
No fuel pump relay in harness
  • Uli661
  • May 18, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 1, 2026
Uli661
U
D
Fox 88 foxbody no power to red and black wire at fuel pump relay
  • drod88
  • Dec 1, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Dec 2, 2025
Mcmahst
A
P0036 P0056 P0137 P0157 2020 Ford Mustang GT
  • AmkoA
  • Jun 16, 2026
  • 2024+ (S650) Mustang -General/Talk
2024+ (S650) Mustang -General/Talk Jun 16, 2026
AmkoA
A
Resolved Holley terminator integration into CCRM
  • BrandonMP
  • Feb 25, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Aug 23, 2026
fasterthangas
F
