What is low rpm, medium-high load missing a sign of? The transgo kit engages OD too soon sometimes and I have to pull the car up a hill at 1400 rpms. I'll get this sorta missing sensation, a jumpy intermittent sensation in the power like 1 cylinder is not firing ocassionally but it completely goes away from 1700 rpms on up. It will cruise just fine at low rpm and low load but it cannot take any moderate throttle or it will start missing like that. It completely goes away with rpm every time, usually completely gone by 1700-1800.
Is this my lack of vacuum spark advance? A lean condition? I am running 54 primary jets and no other complaints, good power, no overheating. I run 19 degrees initial but it was doing it back at 10 as well. There is no vacuum advance possible.
Is this spark, fuel or what? The car is a champ otherwise and I'd like to fix this before my FTI cam arrives.
Thanks guys
Pete
Thanks guys
Pete
... are you running a mechanical pump? ... Maybe the diaphram is weak.
