  • 1994 - 1995 Specific Tech
Low Speed Fan problems
  • Thread starter Thread starter yellowstang1994
  • Start date Start date May 26, 2006
yellowstang1994
338
  • May 26, 2006
Hi guys,
Determined my low speed fan wasn't coming on today. I also noticed the 10amp fuse location in the fuse box (L. Spd. EDF Mtr.) which I guess stands for low speed electro-drive fan motor doesn't get power through it. The fuse is good and I replaced it many times. I guess this means the relay in the CCRM is bad? To ensure this is the problem and not a wiring issue, can I just backprobe pin14 (dk. blue) through the connector with a test light connected to 12V and see if the fan comes on? I don't want to mess anything up further... My high speed fan works fine... comes on when it is supposed to a little under 230* and comes on with the a/c.
Also, if it is the CCRM I really do not have any money to buy a whole new one, they are rather expensive. I'd rather drill out the rivets in it and replace the relay in it. I'm not really sure what to expect when doing this, but am I getting over my head? Thanks guys
HISSIN50
34
129
May 26, 2006
  • May 26, 2006
Ah, I've been doing some research on all this.
THe EDF control is some sort of solid state electronic gizmo that I'm having issues finding info on. Simply stated, there is a safeguard in the cooling system - if the ECT circuit is open, the fan comes on (you dont even need the computer to have power for his to occur). So the default is for the fan to be ON - the computer interupts the pathway to shut it off. I have had issues finding info about what it takes to simulate what the computer does to turn the fan on (does the computer ground or apply 12 volts). Some of this involves the EDF control, which I cant deduce how it works since it's solid state.
This diagram shows a bit of the circuit.
Here is the same circuitry shown a little bit differently.
I also would start at the CCRM and work backwards (the PCM and EDF control relay are two things we cant troubleshoot effectively, so I start at the fan and work to the CCRM, and so on).
As you said, if you have 12 volts at Pin 14 at ~208*F or above, but low speed doesnt come on, that suggests a CCRM issue (or that low speed on the fan or the wiring from the CCRM to the fan took a dump). Oh, you would want the aligator clip on your test light connected to ground (because 12 volts it put through Pin 14, you need ground on the other end of the light to illuminate it).
I'm not one to open up a CCRM - I hate small stuff like that. Here is a picture of the CCRM opened up. I would simply do an external relay instead. You could do so without cutting wires (do Y-solder joints). Or do it right and get a www.DcControl.com unit. I just ordered mine from Brian earlier this week (it's something I've wanted for a long time, though I could have fixed my existing set up - I never liked manual fan switches and all that). I'm very excited to install his controller.
That's what I got for now. Lemme know whatcha think.
Good luck.
yellowstang1994
338
  • May 26, 2006
Thanks for all the help hissin... I'm going to check more into it tomorrow!
V
Cooling fan low speed not turning on
  • vman
  • Feb 27, 2025
1996 - 2004 SN95 Mustang -General/Talk- Jun 24, 2025
vman
V
D
1999 G/T 4.6 A/C clutch not engaging.
  • David B.
  • Apr 26, 2025
1996 - 2004 SN95 Mustang -General/Talk- May 8, 2025
David B.
D
A
Resolved 03 GT Parasitic Draw Fuse 26 (PCM)
  • Antrix
  • Mar 22, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Mar 24, 2025
89ripper
cooling fan questions
  • stackz
  • Jun 5, 2024
1994 - 1995 Specific Tech Jun 6, 2024
stackz
Cooling fan not working on low speed
  • luvformypit
  • Aug 16, 2024
SN95 4.6L Mustang Tech Aug 29, 2024
90sickfox
