lower a arm help please
  • Thread starter Thread starter 02f150hunter
  • Start date Start date Aug 15, 2007
02f150hunter
pa
Aug 15, 2007
  • Aug 15, 2007
hey all i need some help from some people who have done this before. i am taking off my lower a arms on my 89 gt to put to ball joints and bushings in. the back bolts come out fine but my a arm bolts toward the front of the car will not come out i got the nuts off fine but i have beat with a hammer pryed and tried a recip saw to cut them off i dont have a torch set will borrow one from some techs at work if i cant get anywhere anymore tonight anyone else have any idea that you have used the bolt will move when i move the a arm up and down i think the shank that is at the head end of my bolt is rusted into the sleeve in my bushing it seems to me any ideas guys??? i would appreciate it anything at all to try thanks a lot
Fett
766
  • Aug 15, 2007
If they are rusted, soak them down with PB Blaster, wait about an hour, then go at it again.
02f150hunter
pa
Aug 15, 2007
  • Aug 15, 2007
sorry i forgot to add that i soaked them with pb over night last night when i ran into this after i got home from work.
408gt91
114
N.H.
Aug 15, 2007
  • Aug 15, 2007
if it turns but wont back out put a small flat tip in between the head of the bolt,at the same time turn the bolt and the flat tip sideways if you can get a little space then go to a box wrench.thats how i did it in my 91.or once you turn it out of all the threds and it just turns but is not threded in take a smaller diameter bolt and tap it out.
Shakerhood
20+ Year Stangneter
Oct 28, 2004
3,361
211
114
Ohio
Aug 16, 2007
  • Aug 16, 2007
Try an Air Chisel to drive them out. I bought new Bolts and Nuts from Greens before I swapped my new A Arms in and I used Anti-Sieze on them so they will come apart easy if I ever need to take them apart again.
R
Suspension Lower control arms needed
  • racer_dave
  • Feb 9, 2026
1974 - 1978 Mustang II Talk & Tech Feb 20, 2026
Suspension 87 steering wheel slightly wobbles after new Rag joint install
  • R82148V
  • Jun 16, 2025
Fox 5.0 Mustang Tech Jun 24, 2025
R82148V
Suspension upper axle bushings wont go in
  • Stopman33
  • Mar 4, 2025
Fox 5.0 Mustang Tech Mar 9, 2025
stormsedge
G
Resolved Smoking Wiring Issue After GT40 Head Swap
  • Grapes
  • Aug 15, 2026
Fox 5.0 Mustang Tech Aug 22, 2026
Grapes
G
Electrical 88 EEC Injectors batch firing ?
  • Dustin 86GT
  • Dec 8, 2025
Fox 5.0 Mustang Tech Jan 8, 2026
gkomo
