Lower ball joint
You could weld in a sleeve and use a screw in ball joint.
And then do this to the inside pivot.
http://forums.stangnet.com/showthread.php?t=487944
I don't know of anyone selling just the ball joint. Most of the time the whole arm is replaced.
John
Since both the ball joint and spherical bearing are replaceable, you never have to change the lower arm. The ball joint part number is #20034 and the sleeve is #20043 from AFCO Racing.
It is a lot of work though but well worth it when your done.
John
