Lower control arm bolts
  • Thread starter Thread starter j69302
  • Start date Start date Aug 31, 2008
J
j69302
325
Aug 31, 2008
  • Aug 31, 2008
I have TCP eccentric eliminators on my lower control arms. I need to loosen the bolt on both sides and was wondering if it is safe to do so with the front wheel up on ramps with the weight of the car on the suspension. I am not taking the bolt out, or even the nut off, I just need to loosen it slightly
Also, I need to remove the sway bar bushing on each frame rail to grease them and was wondering if the bar is going to try and break my fingers if I remove the bushing brackets witht he weight on the front suspension.
Psydwaze
661
Sacramento, CA
Sep 1, 2008
  • Sep 1, 2008
I would recommend supporting the car by the chassis when loosening any suspension component hardware. Any of the "what if" scenarios will play out better if you're just dealing with the weight of the suspension loading the bolt versus the entire front weight of the car. Safety first.
As far as the anti-roll bar bushings, you're okay to loosen those as long as both sides of the suspension are equally weighted. Either both at full extension or both loaded. If the suspension is loaded unequally the anti-roll bar will have stored energy and will snap back to its at rest position once a bracket or endlink is unbolted.
J
j69302
325
Sep 1, 2008
  • Sep 1, 2008
Thanks.. guess ill wait till I get it off the ramps. was hoping I could save some time without crushing myself
R
Suspension Lower control arms needed
  • racer_dave
  • Feb 9, 2026
1974 - 1978 Mustang II Talk & Tech Feb 20, 2026
C
SN95 Another Coyote swap list
  • catkiller
  • May 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 8, 2026
bjornsn95
New Products From J&M Products - 1979-1998 & 1999-2004 Race/Extreme Duty Rear Lower Control Arms
  • J&M Products
  • Oct 9, 2025
  • Vendor Sponsor Forums
Vendor Sponsor Forums Oct 9, 2025
J&M Products
C
1965 Mustang Lower Control Arm Question.
  • chopper1876
  • Nov 9, 2024
1965 - 1973 Classic Mustangs -General/Talk- Dec 7, 2024
GOvert
G
Fox Alignment Suggestions
  • PonyGTrider
  • Jul 12, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 13, 2025
PonyGTrider
